 Post subject: SEAGATE U5 20 GB
PostPosted: April 18th, 2008, 8:41
Hi to all!
My problem is model ST320413A
FW: 3.54
POWER ON, IT IS FOR 20 SECOND BUSY And LATER HE IS NOT READY...
CHANGING the PLATE IT CONTINUES WITH SAME the CHARACTERISTICS...
Thanks..
Нет ничего невозможного
 Post subject: Re: SEAGATE U5 20 GB
PostPosted: April 18th, 2008, 9:51
Hello sempre
check on terminal and post it here to know what´s happening
best regards
Alberto
PostPosted: April 22nd, 2008, 9:48
terminal report
Interface task reset
1024k x 16 buffer detected
U5 - 1_Disk 3.54 11-03-00 08:01 coonend
ATReset Power Cycling
Ref 01EC - Head Mask 0001 - Switch to full int.
Ready
Stuff Was Unreadable
T>
PostPosted: April 22nd, 2008, 9:58
Hi
Rewrite stuff parameters....T>F command.
Rgds
www.datasave.ro
PostPosted: April 22nd, 2008, 10:25
Thanks ccc!
I do not have experience in using the terminal, where I can find information on commands of the terminal?
:good:
PostPosted: April 22nd, 2008, 11:15
You can find info in the seagate PC3kpci manual for sure.....
Rgds
www.datasave.ro
PostPosted: April 22nd, 2008, 13:34
Thanks for help!
I do not have the manual, nor pc3kpci, only have the terminal usb, as I can learn on these commands?
:good:
PostPosted: April 23rd, 2008, 9:11
Look!
thanks
PostPosted: May 20th, 2008, 14:31
Hi to all!
Please,
How I can rapair this problem for recovery data?
Thanks!
U5 PCI.txt [214 Bytes]
Downloaded 683 times
PostPosted: May 21st, 2008, 9:16
Hi to all!!
Help!!
:fig:
PostPosted: May 23rd, 2008, 15:52
Type :
T>F
Setstuff>ASCIFE
Users browsing this forum: No registered users and 50 guests
