 Post subject: Seagate Barracuda Galaxy 3D
PostPosted: April 25th, 2008, 16:56
please anyone knows how can i depot (stop working the no6 head) from that drive....
the patter of that head is looks like plate with 3 beautiful rings.
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: Seagate Barracuda Galaxy 3D
PostPosted: April 25th, 2008, 17:53
I suppose u want to disable H5. why?
PostPosted: April 25th, 2008, 23:00
Only trying to make a head map but i dont sure if ace products support this hdd, and if u dont get sectors from one platter the most common is u info will be cutted and not completed if u need office infomation, could be if has loock getting sectors , by Raw recovery could works for office ,jpeg, zip, but a DBF, or another file like SQL for example would be cutted and no works the another problem its surely the head left black dust over that platter maybe another´s platters are contaminated too , that´s very common on seagate :( and very worst!
Best Regards
PostPosted: April 26th, 2008, 1:47
i know that beto , but i must try because the files is most of them photos , and word ....
PostPosted: April 26th, 2008, 1:51
pepe the drive works only on terminal mode after 10 times of HM error..., i think with Salvation utility i can ?
PostPosted: April 28th, 2008, 10:03
HM Means Head Mask ,its hard but if u dont have another choice tried that
Best regards
PostPosted: April 28th, 2008, 17:44
if there are surface damages on side 5, the best u can do is to lift up H5 so that it would not touch the surface and spread more dust in the drive. Also it is neccessary to clean the inner parts if there's dust inside from the damaged surface.
Also U can clone the drive leaving out areas of H5.
PostPosted: April 28th, 2008, 22:20
pepe, how i can clone one drive who it is not recognized from the utility because i always have HM....
PostPosted: April 28th, 2008, 23:25
if you need data. u need to change its head. HM mean Head damaged.
If you cut head. You will never get your data back.
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 29th, 2008, 2:23
u said it clicks 10 times, isn't it ready afterwards?
PostPosted: April 29th, 2008, 3:09
no stops after that ...
Users browsing this forum: No registered users and 218 guests
