 Post subject: HDD Heads Transplant: Donor Part Number Matching.
PostPosted: April 29th, 2008, 9:05
Hello again to all,
does anybody know if is it possible to succeed in transplanting Heads Stack from a Donor "Seagate ST38421A Part Number 9M9004-304" HDD to a "Seagate ST38421A Part Number 9M9004-034" HDD?
In other words, is it important to have exactly the same Part Numbers (and Firmware, Configuration Level, and so on)?
Thank You very much :D .
Best regards.
Mark
 Post subject: Re: HDD Heads Transplant: Donor Part Number Matching.
PostPosted: April 29th, 2008, 14:21
Hi Mark
Model, Config, Site code are compulsory for head change
DF :)
DF :)
www.datatracksystem.net
PostPosted: April 30th, 2008, 13:02
Hello darkforce1 :D ,
thank You for the reply.
Anyway, I am still perplexed.
I cannot understand the "sure" relation between Heads Stack and other parameters (as Configuration Level, Firmware, etc.).
Another fact; about "Seagate" ("U4 ST38421A"), here:
http://hddguru.com/content/en/articles/ ... k-Q-and-A/
there is a Table:
"Table 1: The characteristics of donor drive compatibility for head stack replacement"
Regarding to "Seagate", there is written: "+" on "Firmware" and "Country" and a "-" on Part Number; does this mean that Part Number is not important?
My doubt is: can We tell that surely two different (in other Data as Firmware, Part Number, etc.) "Seagate ST38421A" HDDs cannot have the same Heads Stack?
According to the Table, it is necessary to search for the same Firmware and Country, not "Part Number" but I still don'understand; in fact, still If I am correct, Heads Stack (with its IC preamplifier) it's only an analog device (or am I wrong?).
Kind regards :D .
Mark
Users browsing this forum: No registered users and 50 guests
