 Post subject: Yet another Samsung problem
PostPosted: April 29th, 2008, 22:47
Have you guys seen this error, what does it mean?
Samsung SP1604N with this terminal error:
SpnOk
DAC:-00245
H: +00000
UF: 1. 1st Gray err
H: +00001
UF: 1. 1st Gray err
H: +00002
UF: 1. 1st Gray err
H: +00003
UF: 1. 1st Gray err
H: +00000
UF: 1. 1st Gray err
H: +00001
UF: 1. 1st Gray err
H: +00002
UF: 1. 1st Gray err
H: +00003
UF: 1. 1st Gray err
ENG>SRV>
 Post subject: Re: Yet another Samsung problem
PostPosted: April 30th, 2008, 10:16
Dead PCB or dead preamp.
PostPosted: April 30th, 2008, 11:30
Head Gone.
DF :)
DF :)
www.datatracksystem.net
PostPosted: April 30th, 2008, 13:58
I vote for PCB or preamp, though this is not all about voting :)
check the drive with another PCB of the same model regardless of FW revision, if the terminal gives the same, preamp is gone.
PostPosted: April 30th, 2008, 16:59
Either preamp, head or firmware issue (yes, could be)
Does the drive knock at startup or calibrate ?
You can easily test for data out of the preamp (quantitative, not qualitative) and the relevant signals on the PCB with 150 Mhz or more bandwidth scope.
I have discussed this kind of test about two years ago, probably not here... I can't remember.
Regards.
Regards.
PostPosted: April 30th, 2008, 17:11
with such report the drive must be clicking, but let TerraNova answer this question for sure.
Since it is apparent that the drive cannot access any of its heads - most probably preamp is not functioning due to either its own damage or due to lack of proper alimentation from the pcb - Starling an me were suspecting preamp or PCB problem in the first run.
PostPosted: April 30th, 2008, 21:41
Does the drive knock at startup or calibrate ? yes it knocks at startup, no it wont calibrate.
Thank's guys, will keep you posted ....
PostPosted: May 3rd, 2008, 23:38
yes its the head as i swapped with SP1614C (SATA) i got the same errors on terminal.
Can I use SP1614C (patient drive is SP1604N) HDA? Both have the same P/V MS and the donor drive is SATA.
Thank's
PostPosted: May 4th, 2008, 9:22
If no further investigation on the MC is possible in emg. mode , you get no signal at the HSA connector (checked w/ scope or logic analyzer ?) and you are sure it's not a firmware problem , then HSA swap could be the last resort.
Anyway I had some drives with same symptoms fixed : simple firmware issue (the sw on the MC and the code didn't match anymore) , but I was going only to repair the drive not DR.
PostPosted: May 4th, 2008, 21:50
Hy terranova did u check the preamplifier circuit or flex from MHA number its same between donnors?
PostPosted: May 5th, 2008, 12:48
Have u checked with another PCB?
PostPosted: May 5th, 2008, 20:59
Yes Pepe, same results on terminal. click click 8 times and power down.
The donor drive i used is SP1614C, just wondering if it is compatible with the patient HDA, both have the same P/V MS.
Users browsing this forum: Doomer and 116 guests
