 Post subject: IBM-HTS541040G9at00
PostPosted: May 12th, 2008, 20:01
pcb is dead ..try another pcb no luck, using pc3k try to copy nv-ram , its al 00ff meaning cant copy it or ram is toasted ... any solution for that or just call it quit onthis ... any help ?
 Post subject: Re: IBM-HTS541040G9at00
PostPosted: May 13th, 2008, 4:22
I think before you can get some help, you should write a little better, or else it will be hard to understand what do you need.
PostPosted: May 13th, 2008, 9:51
OK YOU right i should do better. here it goes :
igot ibmhts541040g9at00 laptop drive. which has dead pcb. so i try to copy nv-ram using pc3k , and it did that with errors.Then i check that nv-ram file in hex editor ,it only shows me 00 ff on every sector. so obviously nv-ram is not copied .... so my question is any solution for that or how to find a exact pcb which will work on this drive .... i hope i make it clear this time
PostPosted: May 13th, 2008, 15:19
NVram is unique for each individual HDD, so U have to recover the original one or apply a bruteforce attack to find the SA location on the surface...
It is possible that u will need to desolder the original NVRAM ic and check the contents in a stand alone programmer.
U can also try to solder it onto another board having the same ROM version.
PostPosted: May 13th, 2008, 18:18
YEP--Thats what i will do and see if it can be read in a programmer ..... Thanks alot
Users browsing this forum: No registered users and 278 guests
