 Post subject: The best way to remove the remove a burnt motor controller
PostPosted: May 14th, 2008, 23:19
See: http://www.youtube.com/watch?v=976AIzyTyv8
I would not try this for a customer's hard disk but it seems to work well. I suspect it may damage the PCB for a hard disk.
 Post subject: Re: The best way to remove the remove a burnt motor controller
PostPosted: May 15th, 2008, 10:39
Very clever, but I would be hard-pressed to use it. :wink:
The best method for chip removal / replacement is a hot air station, IMHO.
Jon
http://www.datasaversllc.com
PostPosted: May 18th, 2008, 7:43
jono-ats, have you found that in the case of a WD board with a burnt motor controller chip - if you replace it with an exact matching one - is the rest of the board normally working ok? i.e is it enough to swap this chip over to get the drive repaired so the data can be copied off?
Thanks.
PostPosted: May 18th, 2008, 8:40
Hi
From what I have read here when the motor controller chip is burnt out the head preamp usually goes pop at the same time. I would have thought most recovery techs would (at least with a WD) go for a replacement board and swap over the ic containing the adaptive info.
Then you will find out if the preamp is working or not.
Another thing....isn't there a chance the motor is seized? And thats what took out the motor control ic in the first place?
PostPosted: May 18th, 2008, 9:45
Zed:
Sometimes yes; sometimes no, because other components may fail in addition to the controller IC. In a typical failure, there is a hole burned in the I.C., and one of the PCB traces is ruined.
Dick:
In my experience, preamp failure and motor I.C. failure do not occur together often. But I would agree that replacing the PCB and swapping or reprogramming the ROM is the better way in case more than the SMOOTH IC is damaged.
Jono
Users browsing this forum: Protech and 238 guests
