 Post subject: Maxtor Diamondmax Plus 9 120GB-Powered Reverse
PostPosted: May 26th, 2008, 18:22
Hi all,
I was trying to use a Bytecc HDD USB on my Maxtor Diamondmax Plus 9 120GB HDD and ended up powering it up in reverse ( i was not paying attention and didn't think it would fit anyway, but it did) well it started to smoke on the bottom and now i can see the chip that is fried. any way i can fix this?
Thanks in advance!
 Post subject: Re: Maxtor Diamondmax Plus 9 120GB-Powered Reverse
PostPosted: May 26th, 2008, 22:33
Do you need the data, or just want to fix the drive to use? How much is it worth to you?
PostPosted: May 27th, 2008, 9:16
just the data
PostPosted: May 27th, 2008, 12:52
If the data is truly important, the smartest move is to take it to a pro. If it's not, you can try buying a donor drive, and switch the PCB. If you're handy with a soldering iron, you can try and replace or remove the TVS, and/or replace the fuse. You might have got lucky, and not fried the rest of the board.
PostPosted: May 27th, 2008, 12:55
if I switch off the PCB, are the TVS and fuse all on the PCB or are those seperate?
PostPosted: May 27th, 2008, 13:21
TVS and fuse are on the PCB.
Users browsing this forum: No registered users and 45 guests
