 Post subject: Bad head WD1600JB-32EVAO
PostPosted: May 26th, 2008, 17:06
Yesterday morning when I turned the computer on one of the hard drives died.
It is WD1600JB (160GB).It is making clicking sound. Please listen to Attached wav file.
The drive contains all my pictures which only half are backed up.
Is there any thing I can do like changed a heads ,PCB etc. short of spending $3000.
Any help would be very appreciated.
Robert.
http://www.kingfisherphotography.com/misc/bad_harddrive.wav
 Post subject: Re: Bad head WD1600JB-32EVAO
PostPosted: May 26th, 2008, 22:13
Well i did some reading.
When I've put the drive in safe(PCB)mode (3 jumpers closest to the power connector) the drive does not spin up and is not recognized in MHDD at all and when I removed the jumpers MHDD recognized as different drive.
Does it mean the heads are BAD and need replacement.
I'm usually pretty good with fixing "stuff".
I've found the same model drive on ebay for $77 +shipping.
Do I dare to open the drive?
Anybody have any comments, please.
PostPosted: May 26th, 2008, 22:51
Data Recovery is not all that friendly to people good at fixing 'stuff'. An old saying is that a little knowledge is a dangerous thing.. Think of if your family Dog had a tumor, and you didn't feel like paying a Vet for the surgery. Would you try and remove the tumor yourself? If you did, and be realistic here, what would your chances really be of curing the dog of cancer, or of the dog even surviving the procedure?
I am really, really good with all things mechanical and electrical. Really good. Since being a teenager, just about everything I ever tried to fix, I did fix. Being an EE later in life didn't hurt either. However, the first 5 or so drives I opened resulted in NO data, and my humbled self realizing I was way in over my head. I stopped murdering drives, and spent years researching.
If you try replacing the heads without a lot of practice, I can almost guarantee you won't recover a single file, and you at least made it much harder, and more expensive, for someone else to recover your data. Before even doing anything, you need a proper diagnosis, and an accurate one will be difficult remotely.
If you want to try 'something', you can try swapping the PCB. It likely won't help, but it will cost you $77 + , and you can say you tried.
In case I was vague, opening the drive is a really bad idea.
Now, if you've decided that, no matter what, you won't send the drive to a Pro, and you'd just toss the drive in the trash, have all the fun you want. Just don't expect your data back.
PostPosted: May 26th, 2008, 23:33
Well..
Spoken like a real PRO.
Thank you for a response. I'm really, really good with all things I was just being humble.
But seriously.. the data is kind of important to me so what are your rates.
PostPosted: May 27th, 2008, 0:54
Where are you located?
PostPosted: May 27th, 2008, 8:33
That´s case should be checked,by a DR Company, to check ATA Registers, after knocks? reach DRDY DSC?
If its Head problem´s, a way would be, changing the head map , Trying to disables one by one, even when the hdd was dropped, u can tried this method, but of course would be made by a Pro DR Company
Best Regards
PostPosted: May 27th, 2008, 16:44
I'm in Thunder Bay, Ontario, Canada.
 Post subject: Re: data recovery
PostPosted: May 27th, 2008, 23:16
As just you said,your WDhead was bad.The data in your hard disc,I can help you to recover it .Please touch me or E-mail me.Adress:.com.Another,our company website:salvationdata.com.
Beware: another professional spammer from SalvationData
PostPosted: May 28th, 2008, 1:18
davidzhou wrote:
Please touch me . . .
David, this is the wrong forum for that request . . . :lol:
http://www.datasaversllc.com
Users browsing this forum: Majestic-12 [Bot] and 97 guests
