 Post subject: Need PCB for WD1200JD-00HBB0
PostPosted: May 29th, 2008, 9:39
Anybody having PCB for the following WD drive ? Please reply or PM me.
Western Digital 120GB (SATA)
MDL: WD1200JD-00HBB0
DCM: DCBHCTJAH
PCB: 2061-001267-200 AJ
Thanks in advance,
-RDS.
 Post subject: Re: Need PCB for WD1200JD-00HBB0
PostPosted: May 29th, 2008, 12:28
Ragadata,
I don't have your PCB in stock. If you send me good quality picture of your PCB I might be able to find you a compatible PCB you will only need to swap the ROM (U12 Chip). If you can't find your PCB I can repair yours.
We offer HDD (hard disk drive) guarantee PCB repair. Depending on the brand and the model of the HDD the PCB has certain amount of unique information witch can be hard to find a perfect matching PCB. We have the complete equipment and knowledge to successfully repair your PCB, we have over 300 PCB model in stock for parts.
FAQ
What is common problem for HDD PCB?
-HDD not starting, not spinning
-Chip or component burnt
-HDD Clicking (often is a mechanical problem)
What is guarantee?
If we are unable to repair your PCB or your HDD has an other problem witch make it fail there is no charge except shipping.
How can you tell if the repair is successful?
After the repair the following test will be made if they all pass then the repair is successful:
-Computer BIOS detect the HDD correctly
-We are able to read 5 sectors of the HDD randomly
What manufacturer are you supporting?
-Maxtor
-Western Digital
-Seagate
-Quantum
-Others contact us before shipping.
Are you supporting 2.5”/laptop HDD PCB?
Sorry not for the moment.
For shipping fee can you bill my account?
Yes we can!
Francis Parent-Valiquette
http://www.tux-tech.ca/
PostPosted: May 30th, 2008, 16:53
yes send pcb pic that way we can send u compatible pcb for your drive u just have to change rom to make it work .
PostPosted: June 1st, 2008, 5:04
Hi Rameez,
Thanks for your reply.
I've attahed the pictures of my Harddisk (PCB Burnt).
Let me know if you have a compatible PCB. I can change the ROM myself from the patient to the donor.
Pls PM me to discuss about the commercial part.
Thanks,
RDS
PostPosted: June 2nd, 2008, 3:14
Hi Rameez,
Any luck on the PCB?
Do you have a compatible one ?
I can swap the ROM from the patient to the donor.
-RDS.
PostPosted: June 3rd, 2008, 0:26
I have one compatible one in IDE not sata let me know if u need .
PostPosted: June 3rd, 2008, 0:36
Hi Rameez,
I managed to get an exact one.
Once I get it, I'll swap the ROM and get the data out first.
Thanks for your replies.
-RDS.
PostPosted: January 15th, 2009, 14:22
Please help if you can...check this post:
need-pcb-2061-001267-200aj-2c45-lhxt-0007360-5367-t11006.html
PostPosted: January 15th, 2009, 15:34
that type of damaged would more likely take out the preamp headstack.
i would change the headstack too to be on the safe side
if the first option does not work for you
Users browsing this forum: Google [Bot] and 132 guests
