 Post subject: NEED REPAIR SEAGATE MAXTOR 1TB that display 0MB in Bios
PostPosted: June 2nd, 2008, 13:29
I am Using the Seagate TOOLS from salvation data.
And i have this case.
How can i correct this problem to get data back.
Jose
ZeBong
" Россия еще раз"
 Post subject: Re: NEED REPAIR SEAGATE MAXTOR 1TB that display 0MB in Bios
PostPosted: June 2nd, 2008, 14:05
well the ihdd its identifies so means, the recalibration its OK, and its detected ID, so its getting DRD DSC
U need to check on Terminal , to know what´s happening and type some test commands to know , if its loaded Cert tables, for example, thats 0 size looks like SCSI 0 size problem, on Seagate Chettah, maybe translator corruption. but should be checked SA ,or maybe Bad head but thats should be checking with tests to know where its the problem.
Best regards
Alberto from Mexico
PostPosted: June 2nd, 2008, 17:15
When i make CMD MODE
it appers just this
F3 T>
Do You Know what is it ?
Wich command should i use.
Jose
ZeBong
" Россия еще раз"
PostPosted: June 2nd, 2008, 17:58
On that screen turn off and turn on and post it, the log, wich its showing
Some like that
Interface task reset
1024k x 16 SDRAM
TONKA2 - 1_Disk M-31 12-07-05 09:13
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
PostPosted: June 3rd, 2008, 14:03
Thanks Beto,
When i connect the SEAGATE Doctor from salvation to the CMD MODE,
Nothing happen.
Is any other way to connect a disk via COM PORT?
Jose
ZeBong
" Россия еще раз"
PostPosted: June 3rd, 2008, 17:50
Wich model is your hdd,? there are some hdd´s 1 TB wich are not detected by normal terminal because use a technology similar SCSI
Best Regards
PostPosted: June 5th, 2008, 11:36
Here is the foto off the disk.
Can i change the PCB and the disk it will see the data ?
Jose
ZeBong
" Россия еще раз"
