 Post subject: MYSTERY
PostPosted: June 7th, 2008, 16:21
Hello I have an HD Maxtor has reached only for the HD format is with XP installed OS's OK NTFS partition running normal acknowledges in Bios, now comes the mystery! We have removed the NTFS partition via DOS partition created new restarted the computer, guess what the HD started the OS as if nothing had happened I used the MHDD, WINhex nothing, already apaguei simply partitions, and everything returns to normal one can I explain this mystery? ? and how to solve thanks :P
MAXTOR FIREBALL 3
20gb
2F020J0
Luiz
 Post subject: Re: MYSTERY
PostPosted: June 7th, 2008, 16:58
Do you have Norton GoBack, or some similiar utility installed?
Do you have 2 drives in your system? If so, are you SURE you did the right drive?
Have you removed all partitons?
What are you trying to accomplish?
PostPosted: June 7th, 2008, 17:02
We have removed the partitions several times spent a program to reset the Hard Disk sincerely there any software that I can use to format again.
Luiz
PostPosted: June 8th, 2008, 6:39
Based on your explaination, its being tough to understand what u wanaa say and what u wanna do with the hdd.
It is better explain about the problem step by step and say openly what do u want to do with the hdd?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 8th, 2008, 9:21
Sure it is not so HDD formats of any way, you exclude the partition it returns to normal, I tried deleting the partition with various programs partition magic, I wrote zeros with zero fill, already used winhex among other hdd and returned to its original state wheel The XP normally the more you can not erase the data on the HDD, it was not installed any type Goback program among others
Luiz
PostPosted: June 8th, 2008, 10:22
Most probably I could guess the problem. you r deleting your partition and the after restart u see again partitions and datas are at last state.
Its a fw problem. ur operated information is not being stored permanently into the hdd.
few of mod# might corrupt or missing. thats the solution as i can understand having ur information.
__________
THANK YOU
SHAHI
PostPosted: June 8th, 2008, 10:28
I will check this possibility because of maxtor these models are very bad, thanks for your help, I will examine more deeply the problem and therefore the first time I picked up this kind of problem you.
Luiz Brito
Luiz
Users browsing this forum: No registered users and 45 guests
