 Post subject: WD200BB or WD400BB CLICK CLICK CLICK CLICK CLICK
PostPosted: June 13th, 2008, 13:33
Does anyone have any trick with these drives once the heads have been replaced? I have gotten lucky with a few and been able to apply pressure to the head stack mounting shaft (where the case screw goes in) and had the drive calibrate and work for a short amount of time, but is this really the only the only thing that can be done with these drives? It seems like no matter how careful, or what methods I use, the drive just steadily clicks over and over and over and over and over and over again. It's just very frustrating.
 Post subject: Re: WD200BB or WD400BB CLICK CLICK CLICK CLICK CLICK
PostPosted: June 13th, 2008, 14:15
Why would you apply pressure to a head stack?
Don't you have a screw to do that?
www.datarecoveryne.com
PostPosted: June 13th, 2008, 14:18
PostPosted: June 15th, 2008, 7:19
I have noticed that in most cases when drive is clicking it is due to the heating of the read/write channel of the pcb replacing it or the pcb has done the work most of the times .
Users browsing this forum: No registered users and 73 guests
