 Post subject: Odd WD Problem
PostPosted: June 15th, 2008, 18:28
I've got a WD1600 that thinks it has a 2.047.5 terabyte capacity.
It's not the PCB. The heads, sectors, cylinders, etc. are all normal, so I'm guessing the capacity must be determined dynamically.
Is this the result of a bad preamp MUX line? Anybody seen and resolved this problem before?
Thanks.
Jon
http://www.datasaversllc.com
 Post subject: Re: Odd WD Problem
PostPosted: June 16th, 2008, 2:30
some information in the fireware is edited?
PostPosted: June 16th, 2008, 9:29
Susan,
Shei shei for your suggestion.
It might appear that way, but I'm not so sure.
I'm hoping that someone knows the specific module numbers involved. The config module (#42) isn't it, apparently in this case . . .
Users browsing this forum: No registered users and 58 guests
