 Post subject: Maxtor Hard Disk
PostPosted: June 21st, 2008, 21:21
When I formatted this Maxtor hard disk, it generated a format error message. After formatting is done the computer can not read the dard disk anymore.
Questions
1. Is there anyway to fix the problem?
2. I heard that some hard disk can not low level formatted. It will damage its sector alignment. If this the case, what can I do?
 Post subject: Re: Maxtor Hard Disk
PostPosted: June 22nd, 2008, 17:41
Low level format is used for writing zero at every sector.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 24th, 2008, 3:32
Dear ray chen,
I think there must be some serious bad sectors on your Maxtor HDD, and these bad sectors block you to format it.
I suggest you to try to use HD Doctor for Maxtor of SalvationDATA to repair the bad sectors first.
Selina
Email/MSN: selina ATsalvationdata.com
data recovery software and Flash recovery solution
Users browsing this forum: Google [Bot] and 71 guests
