 Post subject: MODEL PALO
PostPosted: June 27th, 2008, 15:35
Hi to all!
Bad two heads?
look logs...
Family selected: PALO
Model................................... : SP0802N
Technological ID
Flash version........................... : tk04b
Heads number............................ : 2
SA SPT.................................. : 832
Modules table used by default
Service Area
Head map................................ : Drive is not ready
Part Number............................. : Drive is not ready
Password info is not loaded: Drive is not ready
Soft reset ...
Ok
HDD resources backup
Read ROM via terminal
Into folder............................. : <HDD Profile>\Data\SABackup\ROM
Test completed
No HDD response
Test completed
No HDD response
Test completed
No HDD response
Into folder............................. : <HDD Profile>\Data\ROM
No HDD response
SA structure test
Reading modules...
00 FSI.................................. : Drive is not ready
02 FIT.................................. : Drive is not ready
04 MLIST................................ : Drive is not ready
05 SRVTBL............................... : Drive is not ready
58 SEEKTIME............................. : Drive is not ready
5D CONFIG2.............................. : Drive is not ready
06 CONFIG............................... : Drive is not ready
07 SNTBL................................ : Drive is not ready
08 BISPT................................ : Drive is not ready
09 BRSLT................................ : Drive is not ready
0A CRITERIA............................. : Drive is not ready
Drive is not ready
Soft reset ...
Ok
Term log
SpnOk
H: +00000
SK C: 0000FB69
SpnOk
DAC:-00419
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
ENG>SRV>SpnOk
DAC:-00181
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
SK C: 0000F732
UF: Seq Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
SK C: 0000F92F
UF: Seq Sk err
H: +00001
UF: 1. 1st Gray err
ENG>SRV>SpnOk
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
SK C: 0000F91E
SpnOk
DAC:-00145
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
SK C: 0000F44C
UF: Seq Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
ENG>SRV>SpnOk
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
SK C: 0000F4BE
SpnOk
DAC:-00158
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 1. 1st Gray err
ENG>SRV>
Нет ничего невозможного
 Post subject: Re: MODEL PALO
PostPosted: June 27th, 2008, 19:28
i have never used pc3k, but it looks like head 0 crash.
Somebody? :shock:
Janos
PostPosted: June 28th, 2008, 9:42
Head gone.
DF :)
DF :)
www.datatracksystem.net
PostPosted: July 1st, 2008, 18:17
PCB or preamp most likely
PostPosted: July 2nd, 2008, 8:54
I will verify preamp!
Thanks Doomer!!!
:good:
Users browsing this forum: No registered users and 70 guests
