 Post subject: Hard Disk data Recovery
PostPosted: June 27th, 2008, 21:26
Hello guys
My maxtor hard drive is not detecting even it was detecting when i attached with my computer time ago.
I don't care about my drive but all i need to recover my all data which is in my hard disk... is there any chance i can recover it. ( drive is not spinning).
I check all the method , cabling but nothing worked for me.
Please help .
Thanks.
 Post subject: Re: Hard Disk data Recovery
PostPosted: June 28th, 2008, 3:28
Is there a chance you can recover it? Possibly, depending on your skill level, the tools you have access to, etc... Based on what you've said, and not said, Assuming it isn't something super simple (Bad power supply, computer not plugged in, etc), it's likely something you won't be able to do.
Is there a chance that a professional can recover your data? More than likely.
PostPosted: June 28th, 2008, 9:01
Contact a Professional. otherwise you will mess it up.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: June 28th, 2008, 15:23
Try only connecting power not data cable. If starts, data cable is reversed or ide controller failing. If the hdd doesn't start on other pc, the disk has to be serviced.
PostPosted: June 29th, 2008, 3:47
time to send it to the pros
your more likely looking at a preamp head break down
its a common problem with maxtor hard drives
Users browsing this forum: Bing [Bot] and 222 guests
