 Post subject: Clicking Maxtor 6Y250P0 - Can anyone help?
PostPosted: June 26th, 2008, 5:32
I have the following Maxtor 6Y250P0 YAR41BW0 which just clicks constantly after a few seconds. What I have done so far with SalvationData Maxtor tools:
1. Safemode booted to SA-C and made loader from SA-A. Loader boots drive from safemode with no problems. Have perfect read/write access to SA-A and SA-B.
2. Checked firmware. No bad sectors or firmware problems.
3. Removed heads 0,1,2,4,and 5 one at a time but still get clicking.
4. Inside looks visually good. Nothing is binding the headstack.
This one is driving me NUTS. I'm thinking its a pcb problem or maybe headstack but not sure. If anyone has any suggestions it would be greatly apreciated. Thanks :mrgreen:
 Post subject: Re: Clicking Maxtor 6Y250P0 - Can anyone help?
PostPosted: June 26th, 2008, 9:01
Tried an hot swap , and check if hdd reach DRDY DSC, if its still knocking the most probably its a MHA damaged,
if no tried to check SA ,structure and of course did a backup of SA ,
Best regards
PostPosted: June 29th, 2008, 6:51
If the drive boots with a loader it couldnt be a pcb issue sometimes this happen when rom is corrupt check if drive has external rom . If not like beto said MHA issue .
PostPosted: June 29th, 2008, 21:01
I was thinking rom as well. Thanks for the help. Does anyone have a rom? The pcb does have an external rom.
6y250p0
yar41bw0
k,g,g,d
sn: y60******
PostPosted: June 30th, 2008, 1:24
If someone could send one to my email it would be greatly apreciated. Thanks.
thatdellguy @ gmail.com
PostPosted: June 30th, 2008, 3:44
Do you accept PC3K UDMA format ?
Dobre
Murphy was an optimist
PostPosted: June 30th, 2008, 9:32
try to disable all heads except for head 3 - it should come ready
probably drive has more than one dead head this is why this - "3. Removed heads 0,1,2,4,and 5 one at a time but still get clicking" doesn't help
try to find out dead heads and disable them
do whatever you want after :)
PostPosted: June 30th, 2008, 9:33
--deleted--
PostPosted: June 30th, 2008, 14:03
I did try only head three but still get the clicking noise. Even tried the special head specific loader for Calyspo drives with no clicking. The weird thing is that I can read the firmware perfectly from head three with a ldr and it doesnt click. Disabling other heads was the first thing I tried. From 50% to 100% of the rom is empty making me think the rom is at fault or incorrectly programmed. The only problem is that I have nothing to compare it to at the moment. Other similiar roms with YAR41BW0 make use of the last half of the rom.
PostPosted: June 30th, 2008, 17:11
I have PC-3000 version. If you want it I can send it to you.
PM you e-mail to me.
www.datarecoveryne.com
PostPosted: June 30th, 2008, 17:24
first of all if ROM is bad - drive will not spin up
Didn't you think what code will spin up the drive if ROM is bad?
And ROM has CS - drive will not spin up if ROM has bad CS
PostPosted: June 30th, 2008, 18:29
"first of all if ROM is bad - drive will not spin up"
I knew that.
"Didn't you think what code will spin up the drive if ROM is bad?"
I don't understand this sentence.
"And ROM has CS - drive will not spin up if ROM has bad CS"
I knew that. I wanted to compare it to a good rom.
PostPosted: July 11th, 2008, 15:32
Does anyone have a rom backup for this drive? Thanks.
Users browsing this forum: Bing [Bot] and 206 guests
