 Post subject: Wanted PCB for WD2500BB-98GUA0
PostPosted: July 3rd, 2008, 15:12
Hi, I desperately need to get the data from this drive. I'm guessing that the PCB has died but nothing seems to have burned out. I tried another WD PCB and the drive spins but obviously is not readable without the correct PCB. Other info on the drive is as follows: Date: 31 Jul 2004, DCM: HSCACTJAA, on the PCB itself: 2060-001266-001 REV A, on the Barcode: 2061-701265-200 AL XC1X68 AWBY 6 0005380 6385. Thanks in advance for any help.
 Post subject: Re: Wanted PCB for WD2500BB-98GUA0
PostPosted: July 6th, 2008, 11:55
can u show the pic of the pcb ?
PostPosted: July 7th, 2008, 9:19
I have a PCB to suit this drive.
Although you WILL have to swap the ROM chip over, as all later WD drives.
msn me sean@pcimage.co.uk if interested.
Cheers
Sean
PostPosted: July 28th, 2008, 15:15
Hi - I got a replacement board which worked for a few mins then started making beeping sounds. I have a soldering iron, which is the ROM chip? Sorry can't send a photo at present - how much do you want for the board? Cheers, Jan
PostPosted: July 28th, 2008, 15:46
1266 will work too
but u have to swap the ROM ( U12 )
PostPosted: July 30th, 2008, 0:38
I have this pcb in my stock PM for details .
Users browsing this forum: No registered users and 98 guests
