 Post subject: WD 120 - 00GUA0 Problem
PostPosted: July 2nd, 2008, 20:33
Hello friends.
I have a drive when scanned in victoria first 4 blocks (UNC) the rest of blocks are showing (IDNF) ?????????????
Is that a SERVO problem ?
Thenks alot friends
 Post subject: Re: WD 120 - 00GUA0 Problem
PostPosted: July 3rd, 2008, 2:33
U can test the Firmware using check_wd
Then post the results...
Mikippp
PostPosted: July 3rd, 2008, 6:38
Hi miki
I tested it already by HD doctor for WD
All FW modules are ok.
thanks for advice
PostPosted: July 13th, 2008, 10:16
If u get IDNF errors anywhere while scanning then and then u rescan the drive it doesnt show up then check ur pcb if not then could be a translator issue .
PostPosted: July 14th, 2008, 7:10
hi rameez
thanks you for answer
If the problem is a translator issue what should i do ?
I already checked all firmware modules and they are all ok
thank you
PostPosted: July 14th, 2008, 10:07
If all modules are ok, so u could be get some weak head, tried to check on wich heads show the UNC errors
Best Regards
PostPosted: July 14th, 2008, 12:58
If the drive shows some UNC sectors, this can be media problem also.
If one of the heads is weak, this comes everywhere on the area in good and bad bigblocks.
If the drive has only 4 UNC sectors, and after this the sectors are good, i guess this is only media problem.
Regards,
Janos
PostPosted: July 14th, 2008, 14:40
Regenerate translator and do a full erase to repair the drive .
PostPosted: July 15th, 2008, 12:17
thanks rameez
but how can I regenerate translator using hd doctor for Wd ?
thank you
Users browsing this forum: Google [Bot] and 265 guests
