Hello guys,
I have been playing around with some pcb's and since my knowledge in electronics is very limited I had some questions. I hope someone can sheet some light on these for me.
Ok, I now have gotten somewhat comfortable when looking at a pcb so that I know what most of the IC's do. I noticed that the Maxtor and WD PCB's are pretty good at labeling components with a value or number. Unfortunately Seagate does not provide that luxury.
I could not hepl but notice the R, C, labeling on Maxtor and WD PCB's and I assume that
anything labled with an R = Resistor
anything labeled with an C = Capacitors
Can someone please confirm this for me?
Also when I measured what I believe to be the resistance with a mulimeter I received different values then expected. I measured R22 and I thought It should be 22Ohm, but it turned out to be somewhere around 650 Ohms. I measured this both on a fully functioning Caviar SE and on a faulty one. I must add that the multimeter that I was using is not state of the art
, but I know it's functioning.
Ohh, also before I forget, what does the E label mean on the backside of the PCB?
Thanks allot!
