 Post subject: Hitachi not loading open module error
PostPosted: July 18th, 2008, 12:18
HI all
need help on this problem...
when i hook up my drive to pc3k... it do not intialize but when i choose its family it comes up and gives me error open module not open .....
and i know with out open module u can not intialize this thing... i will appreciate any clue to fix this problem
thanks
 Post subject: Re: Hitachi not loading open module error
PostPosted: July 19th, 2008, 18:00
If the drive is one of the HSS541, HTS721or other new series then this is a common problem. Pc3000 does not allow writing to factory copy of modules and the problem is usually within the PSHT (P-List). Double check by looking in the modules list and check all modules.
I've been doing a lot of development on these drives, and whilst I can now write to the factory modules, getting the drive to come ready still eludes me :(
I dont give up though.
PostPosted: July 21st, 2008, 12:59
Yes that is right ... it is HTS721drive .. you did describe the problem right... so any solution i can try to solve it or call it quit
PostPosted: October 4th, 2008, 4:41
HDDTECH wrote:
HI all
thanks
maybe NVRAM is wrong ,maybe RSVD and USAG is lost
PostPosted: October 4th, 2008, 11:52
What is a model of the drive?
Which PC3000 version are you using?
www.datarecoveryne.com
PostPosted: October 16th, 2008, 14:02
moDEL # hts721 SERIES 100GB ...USING PC3K UDMA IT IS THE NEWER VRSTION ... ANY HELP WILL BE APPRECIATE
PostPosted: October 16th, 2008, 14:18
Did you try to start using "Load resources from..." either profile or database of similar disk? This should allow you to check SA condition. Let me know what you find.
