 Post subject: Samsung SV4002H Klciking Noise
PostPosted: July 21st, 2008, 3:32
Dear Friends,
I have a Samsung SV4002H, 40GB , Victor Hard disk drive.
Suddenly it gives Clicking Noise. not detected
Terminal Shows the
sAL + 1020
c: 004E H:00
sAL + 1020
c: 004E H:00
sAL + 1020
c: 0051 H:00 ...
In which area the problem is?
Data is important.
thanks,
amit shah
 Post subject: Re: Samsung SV4002H Klciking Noise
PostPosted: July 21st, 2008, 3:41
can be anything from corrupt firmware which in your case is very unlikely or preamp damaged
not detected there no information getting to the head at all
if you need the information of the drive pay some $$$$$$$$$$ on a another logic board of the same type
PostPosted: July 21st, 2008, 10:34
Replaced the same type PCB but the same terminal error is continue.
thanks,
amit shah
PostPosted: July 21st, 2008, 11:31
Can you read the m/c ? If not, head gone. Could even be a corrupted rom. Check for content. Also, check the error lists.
PostPosted: July 23rd, 2008, 7:37
How to check the m/c machine code? and error lists. is any specific command on the dbg> debug mode?
New strange behaviour, I have same type of pcb in the 20gb samsung hard drive. the 40gb(failure) hard drive pcb is working fine in the 20gb hard disk.
but the 20gb hard disk pcb is not working on the my failure 20gb hard disk drive.
Thanks,
amit shah
PostPosted: July 23rd, 2008, 7:41
Thanks,
amit shah
This is not too interesting. :)
Some of the board have newer fw part for loading the platter-pairs...
Regards,
Janos
PostPosted: July 23rd, 2008, 7:50
Pcbs may be identical, some difference is in rom. Maintenance cylinder aka m/c can't be accessed in debug, need some tool like pc3000 or so.
PostPosted: July 23rd, 2008, 8:25
I have pc3k tool. but new for that.
Can you give me tips or step for checking?
thanks,
amit shah
PostPosted: July 23rd, 2008, 9:23
Wich ATA registers show´s after that log?
Users browsing this forum: No registered users and 258 guests
