 Post subject: Maxtor 4R060L0 SA-C boot file needed
PostPosted: July 30th, 2008, 6:39
Can anyone share it?
4R060L0
RAMC1TU0
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Maxtor 4R060L0 SA-C boot file needed
PostPosted: July 30th, 2008, 12:57
This drive does not have an ALTSA <Program C> no use searching for it . This hdd has program B but i dont know much about it .
PostPosted: July 30th, 2008, 17:25
Thanks rameez.
I ran zerofill due to logical bad errors, and was thinking to run full scan to add bad to plist.
but after starting zerofill, after few mins break head was stucking then i thought its better to turn off power to direct scan to add plist, after turning off the power then the hd is detected as factory mode, i tried to boot in safe mode but after hdd reset it does not get ready status. thats why i was searching for selfscan at SA using SA-C file if available, now i think time to leave the hd.
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot], Pi0tR and 311 guests
