 Post subject: Rom File for the fujitsu Model MhT2040at , Firmware ce-0022
PostPosted: July 30th, 2008, 16:50
I have a hdd gives rom is corrupted and head is continuesly clicking.
Hard disk has readiness.
So, I would like to update the rom.
Can any one have Rom.bin for the fujitsu Model MHT2040at , Firmware ce-0022.
thanks,
amit shah
 Post subject: Re: Rom File for the fujitsu Model MhT2040at , Firmware ce-0022
PostPosted: July 31st, 2008, 9:22
Very, very much doubt the ROM is bad.
Anyway the ROM's for MHT and above are pretty much unique I believe.
More like head failure.
PostPosted: July 31st, 2008, 10:59
At the intialize the utility it said the Rom is bad. So First I would like to check by writing rom.
Thanks,
amit shah
PostPosted: July 31st, 2008, 15:41
thinclient,
Well, wrong ROM for MHT can cause some clicking, but unlikely.
ROM for MHT is very unique, which means each drive has its own ROM.
Transporting ROM from one MHT to any other MHT will not work,
even if Model No, FW and all parameters match.
So to put it simply - you fuxxed if you don't have original ROM.
btw. what program you use which reports "corrupted ROM" ?
PostPosted: August 1st, 2008, 7:57
Do you mean "ROM reading is not implemented in this utility...... Started using defaults"??? (or something like that)
This does not mean the ROM is bad.
My moneys' on the heads :-)
PostPosted: August 6th, 2008, 16:43
I would confirm Sean...
Users browsing this forum: No registered users and 106 guests
