 Post subject: Maxtor 6Y080L0130403
PostPosted: August 2nd, 2008, 2:17
Please help me out! I have the defective drive details as below:
Model: 6Y080L0130403
S/N: Y3HBSLRE
Code: YAR41VW0
I have some 6Y080L0 YAR41BW0 drives, but no YAR41VW0. Can I use the modules from the YAR41BWO drives as donor to the defective drive.
Thank you
 Post subject: Re: Maxtor 6Y080L0130403
PostPosted: August 2nd, 2008, 7:19
No. Different OVLs etc. - Other modules can be borrowed from same family but depends on what's the problem. Need the data or the drive (for repair) ?
PostPosted: August 4th, 2008, 1:20
Maybe you can't use YAR41BWO to saveYAR41VWO.
The Model No. and the Code No. should be the same and the first 3 No. of S/N should be same. :mrgreen:
PostPosted: August 4th, 2008, 4:25
Thank you so much for your help! :good:
Hi Black ST,
I need the data from the drive, but the failed drive can't be accessed. I thought there maybe something wrong with the firmware. So I need a donor drive. Can you give me a suggestion? What should I do? Find the hard drive as "hddgenie" said or can use the hard drives which I had?
Thank you for your futher help!
PostPosted: August 4th, 2008, 10:16
if u think its something wrong with SA u should be access on safe mode, i suppose the ATA registers on master mode its DRDY DSC then ABRT so , access on safe mode and check SA structure
PostPosted: August 4th, 2008, 10:48
What are the symptoms of the drive?
What for tools do you have?
You should find the firmware in Hddguru files
Best regards
PostPosted: August 4th, 2008, 14:31
First access the defective drive in safe mode, determine which modules are corrupted (and if SA is readable), determine ROM and then find a suitable donor.
Of course don't touch for godness sake the adaptive data !
Always make a backup of the SA. And anyway if the drive doesn't click at start it's a good symptom.
PostPosted: August 5th, 2008, 5:35
Hi Mgic01,
I think first you need confirm whether it is necessary for you to change the firmware with a donor?
If this problem is not caused by the SA problems , you can fix it very easily.
Professional is who always learning and sharing!
PostPosted: August 7th, 2008, 4:24
Thanks for all of your kindness!
Best regards
The symptoms: the Hard drive can't access the BIOS. From other note in this forum, I guess the firmware of the hard drive failed. The note said that:" if a hard drive is not seen in the computer or bios. its more likely going to be a firmware problems or a damaged logic board or damaged preamp head." So I want to find the donor at first.
Tools: I used R-studio, MHDD and some freeware of firmware repair :wink:
"You should find the firmware in Hddguru files", thank you for your good suggestion, I will try to search the firmware from Hddguru files later.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], michael chiklis and 77 guests
