 Post subject: working out what component is what
PostPosted: August 7th, 2008, 4:47
I'm just trying to work out what kind of component i sizzled on my PCB. can you get pcb maps or something?
File comment: its obvious to see
 Post subject: Re: working out what component is what
PostPosted: August 7th, 2008, 4:58
This is a seagate drive, and you have one short TVS diode. :)
Regards,
Janos
PostPosted: August 7th, 2008, 5:11
so whats a TVS diode? and are these common?
PostPosted: August 7th, 2008, 5:25
it is a seagate barracuda 7200.9 so what size tvs should i be looking at and specs i should be after? Janus the man :)
PostPosted: August 7th, 2008, 5:30
The TVS is quite easily identified because it is a rather large black component with just 2 contacts to the PCB, and is clearly seen damaged in your picture. Many HDDs have TVS diodes, I often have Samsung HDDs with damaged TVS, but pretty much any Seagate PCB will have a suitable power diode you could use.
But without the correct tools, you may only end up making things worse!
PostPosted: August 7th, 2008, 5:33
im hooked up with the guy at work he has the tools however are these common like with sizes and power or are there an array of choices?
PostPosted: August 7th, 2008, 5:48
If you post here a picture of the PCB from your 40GB Seagate PCB I can tell you if there is a component on there that can be used.
PostPosted: August 7th, 2008, 6:05
ok too the left of the screw im guessing is wat ill need but if not how do i know the specs?
PostPosted: August 7th, 2008, 6:16
In fact this is the one you need
www.datasave.ro
PostPosted: August 7th, 2008, 6:23
that was the one i was thinking , im getting it sorted tomorrow so ill tell u how i went thanks bud
PostPosted: August 8th, 2008, 22:49
ok tvs is replaced but no power up:( any help?
PostPosted: August 8th, 2008, 23:12
The TVS has a polarity. If you put it in backwards it will fail.
Just remove it altogether and see if drive powers up. Makes sure you have a good power supply as noted.
http://www.datasaversllc.com
PostPosted: August 9th, 2008, 15:31
if its reversed the supply will not start after u plug in the hdd . does this happen when u plug hdd .
PostPosted: August 9th, 2008, 17:22
If it is not a chinese product.... :mrgreen:
Janos
Users browsing this forum: No registered users and 78 guests
