 Post subject: Wanted - Maxtor 120GB 3.5' ATA HDD
PostPosted: August 10th, 2008, 11:40
Help needed... Anyone able to sell me the harddisk with the following specs:
-DiamondMax Plus 9
-120GB ATA/133
-Code: YAR41VW0
-Part: 6Y120L0040411
-PCB large chip: C8-C1, 040111300
 Post subject: Re: Wanted - Maxtor 120GB 3.5' ATA HDD
PostPosted: August 11th, 2008, 14:14
What do u need HDA or PCB ?
PostPosted: August 11th, 2008, 22:52
Need a full working hdd, as I going to do hot swap pcb operation... Any luck on your side??
PostPosted: August 12th, 2008, 15:01
I have working PCB , if its a pcb fault then whole hdd is not req .
PostPosted: August 13th, 2008, 1:10
Tried that.... Issue I have is with the System Area, read/write fail. The only option now is to do a hot swap PCB, therefore need a working hdd.
Users browsing this forum: pepe and 81 guests
