 Post subject: Uploading ROM
PostPosted: August 11th, 2008, 10:41
Hello friends,
My question is which parameters should I match to upload a ROM file ?
Is it full model parameters only ? or full DCM parameters only ? or both ?
thanks for any help
 Post subject: Re: Uploading ROM
PostPosted: August 11th, 2008, 11:39
The same ROM version, if possible.
If unknown . . . . as with a blown ROM . . . . with WD drives, the same and complete model number (e.g. WD400BB-23JHC0) is often enough. To get closer you can match DCM and date but it's not usually necessary in my experience.
http://www.datasaversllc.com
PostPosted: August 11th, 2008, 12:29
Thanks for advice Jono-ats :)
Thank you
PostPosted: August 11th, 2008, 14:51
Not necessary in normal WD drive but as for marvell its not the same .
PostPosted: August 11th, 2008, 17:22
Hello Rameez,
What should I match when uploading ROM with WD Drives ?
Thank you
PostPosted: August 12th, 2008, 15:15
The CPU should be same while changing ROM.
PostPosted: August 12th, 2008, 16:11
Thank you Rameez
Users browsing this forum: No registered users and 35 guests
