 Post subject: Yet another Samsung HD501LJ problem
PostPosted: August 14th, 2008, 0:10
SAMSUNG HD501LJ 500G SATA, detected normal under PC3000, unable to access data using DE. Checked firmware all ok. Reading service track gives error in head 0 and 1, the rest are ok.
Is there anyway to fix and get the data?
Thank you so much.
Reading service tracks
Into folder............................. : <HDD Profile>\Data\Tracks
Selected heads.......................... : 0,1
Read sector error (c: 0,h:0,s: 3)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 4)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 11)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 12)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 13)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 14)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 15)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 16)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 17)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 18)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 19)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 29)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 30)(PIO Mode data receiving timeout : device error detected (AMN))
Cyl : 0; Head : 0....................... : Read with errors
Read sector error (c: 0,h:1,s: 3)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 4)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 11)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 12)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 13)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 14)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 15)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 16)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 17)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 18)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 19)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 20)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 29)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 30)(PIO Mode data receiving timeout : device error detected (AMN))
Cyl : 0; Head : 1....................... : Read with errors
 Post subject: Re: Yet another Samsung HD501LJ problem
PostPosted: August 14th, 2008, 9:33
Hy terranova if u tried to access sectors, what do u got, ABRT?, its said the HDD reach DRDY DSC, right and when u tried to read sector x sector u got ABRT?, did u tried to did an imagen using head map?
PostPosted: August 14th, 2008, 9:46
Check PM it's not a thing to be shared HERE.
PostPosted: August 16th, 2008, 8:15
hi beto sector 0 has something, the rest of sectors nothing.
PostPosted: August 16th, 2008, 10:11
Go ahead and share it and post your findings. We like reading stuff like that. 8) Dont forget, Blacky doesnt run this forum.
PostPosted: August 16th, 2008, 12:39
stts, do you have any opinions on what is wrong with this drive?
Users browsing this forum: Majestic-12 [Bot] and 216 guests
