 Post subject: 6y080l Maxtor
PostPosted: August 16th, 2008, 4:04
I was able to "fix" the firmware and have the drive recognized in the bios and xp. That did not last long and now when i try to put the loader back on, it starts to load then goes to busy and the drive won't load the loader. I do detect a single click (i presume one of the heads) before it goes to busy.
Any ideas ?
Robert
P.S. it did seem that perhaps some of the head were not working, when i looked at the binary (hex) there were some information then all zeros.
4am here so if that doesn't make alot of sense sorry
 Post subject: Re: 6y080l Maxtor
PostPosted: August 16th, 2008, 4:14
The heads move together so it's not "one" of the heads. You simply haven't fixed the FW. How did you fix it ? (which tool/s) ? Post log if possible.
PostPosted: August 16th, 2008, 4:15
PostPosted: August 16th, 2008, 10:47
Ok i stand corrected then. I'm using pc3000 ..... firmware loaded.... it was recognized by the bios.... appeared to be working fine then it quit. Now it will not accept the firmware. starts to load then goes to busy and the drive can't be read by the program.
PostPosted: August 16th, 2008, 10:48
Also i noted it would show as 2 heads instead of 16....
PostPosted: August 16th, 2008, 11:03
If by chance i'm not using the correct firmware.
YAR41BWO N,M,B,A
6Y080L0422611
S/N Y25AHE0C
M6FYA
