 Post subject: Repair Mac File Structure
PostPosted: April 9th, 2008, 22:58
When R-Studio, TestDisk, and PC-3000 DE fail to detect or repair a Mac partition what else could I try? My recovered image is perfect with no defects. Either the customer tried to install the OS or someone deleted it. I believe it has a HFS+ partition on it. Even recovering the file names from a raw recovery would be helpful. Thanks.
 Post subject: Re: Repair Mac File Structure
PostPosted: April 9th, 2008, 23:15
I found an answer to my question.
PostPosted: April 10th, 2008, 4:11
For worst cases I use an Apple machine...
PostPosted: April 13th, 2008, 23:43
mac fils sys is HFS or HFS+,so all the sofwares you mentioned have to support its format!
if you insured you image is completed,you had better scanning it on MAC platform.you must have been an expert on working with MAC ,understanding its logical disk structure and inner-workings of macintosh disk! of course it would take much of your time!
on mac os,you can try norton,techtoolpro ,data rescue for data recovery ,if disk structure has been damaged seriously, modification manually with WINHEX or diskEditor will be your last straw.
coolmac
PostPosted: April 18th, 2008, 3:34
PostPosted: May 8th, 2008, 18:20
So what did you find?
PostPosted: May 16th, 2008, 17:00
Owning a Mac computer has many advantages in data recovery. 8)
PostPosted: May 17th, 2008, 3:41
Correct. And since i started using them they became my favourite machines. :)
A pity PC3K cannot work on them.
Dobre
Murphy was an optimist
PostPosted: August 17th, 2008, 5:12
Hello to all,
I used this guide to fix my MacBook it worked well
http://www.fixya.com/support/r935084-mac_repair_disk
I was quite happy with the results, till one of my friends told me this might damage my Mac.
Is it possible that this tool will cause me trouble in the future? Does my friend know what he is talking about?
Thank you,
Wends.
PostPosted: August 19th, 2008, 11:10
Hello
Is interesting the posted guide, I solve alot of cases of files problems with Linux Systems (Ubuntu, Debian, SuSe, ...)
Bye
