 Post subject: WD1600JD
PostPosted: August 18th, 2008, 13:42
Hi Guys .. couple of questions
First .. What are (if any ) jumper settings for safe mode on
western digital sata drive ( as there is no Master/Slave/CS)
So here's the problem:
Drive is occassionally recognised in Bios ( but not always)
Using WD Doctor, I can't download rom, Primary SA fails.
BUT: Sec SA is good, and I can read data sectors from within WD DR.
I've tried re-writing mods, but always fails.
any hints greatly appreciated
Steve
 Post subject: Re: WD1600JD
PostPosted: August 18th, 2008, 13:51
Check contacts between pcb and hda, first. Then I vote for rom or head problem, as sa2 is ok and does not accept rom programming.
PostPosted: August 18th, 2008, 13:55
I removed the pcb , and still can't get to safe mode.
PostPosted: August 18th, 2008, 20:11
Almost Head 0
PostPosted: August 19th, 2008, 6:54
Almost certainly weak H0, or at least flakey SA on H0
Try and get it recognised and image it quick. ;-)
Sean
PostPosted: August 19th, 2008, 11:17
Hi
Put all 4 jumper and drive will go in safe mode.
DF :)
DF :)
www.datatracksystem.net
PostPosted: August 19th, 2008, 11:27
SATA, DF, SATA !!!
PostPosted: August 19th, 2008, 21:14
Well I kinda figured it was head 0. but was hoping not.
I'm still a little puzzled why I can't read the rom.
PostPosted: August 19th, 2008, 23:42
Jumpstarting - safe mode - you should.
PostPosted: August 20th, 2008, 0:13
That was one of the original questions. How do I get the sata to safe mode?
normally if I remove pcb from drive it would go to safe mode .
This one however doesn't.
This is one of the BIG problems with the Salvation products, lack
of good documentation :(
PostPosted: August 20th, 2008, 0:27
Sadly, yes. Have you tried contacting Laura? Maybe she can address correctly your technical question. They have much improved, anyway. This has to be said.
PostPosted: August 20th, 2008, 0:32
that was my next move ;) But I think it will be tech support instead of Laura .
PostPosted: August 20th, 2008, 2:00
Hi BlackST
SATA, DF, SATA !!!
I know and I am talking about SATA only. Just try what i have posted and things will be clear to you.
DF :)
DF :)
PostPosted: August 20th, 2008, 2:57
I tried all 4 jumpers and yes it went to safe mode , also did some different tests ..safe mode
is the 3 jumpers closest to the data cable . (PM2,OPT1,OPT2) (By the way, Salvatation
didn't give this info, and what they gave was WRONG)
Still can't read rom though :(
Thanks DF
and thanks all that answered
PostPosted: August 20th, 2008, 3:08
no please put all the 4 jumpers to remain in safe mode. do not use 3 jumper settings
DF :)
DF :)
PostPosted: August 20th, 2008, 3:45
Well I still can't read rom :(
Am I missing something, can the rom be bad ?and I still be able to
read SA?
either that, or there is a bug in WD doctor :?
PostPosted: August 20th, 2008, 4:01
DF :)
PostPosted: August 20th, 2008, 4:23
Drive is based on Marvell or WDC controller?
MDL is WD1600JD-xxxxxx?
Mikippp
PostPosted: August 20th, 2008, 4:35
wd1600jd-75hbb0
WDC controller
rom is U12 25p10av chip
PostPosted: August 20th, 2008, 5:02
If controller is WDC and Drive is SATA some techno commands are blocked by Marvell bridge 88i8030
U can use Chk_wd for testing SA, or U can use compatible PATA board 2060-701265-xxx REV A from WDxx00JB-00GVA0 / WDxx00JB-00GVC0 (ROM must be replaced/reprogrammed)
ROM can be readed in this way
read-write-serial-flash-wdc-logic-boards-t7192.html
Mikippp
Users browsing this forum: No registered users and 132 guests
