Forum rules
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba HDD2190 picks up in the bios but not windows
PostPosted: August 13th, 2008, 5:18
CK wrote:
I've heard of a well known DR company removing the platter and turning it upside down on a Toshiba drive when the customer did not proceed with the job. The depths some companies will go to!
I know exactly what you mean!! I often recieve HDD's with massive platter damage, but heads seem intact and filter is clean! Also, the previous DR company it went to were able to get a full recovery and even provided a file list. Customer did not approve their overpriced quote! The worst thing is I have got many disks with the same story, all from the same DR company!
There is professionalism, and then theres just plain old vandalism!! :-(
PostPosted: August 13th, 2008, 7:13
Lets Name and Shame them!
PostPosted: August 13th, 2008, 20:50
I also have met platters upside down and also I recovered the full data area after an MHA replacement but it was overwritten with garbage from LBA 63 till the end of the drive. And some other tricks... Just let me say one word: Kurt
So it is the best to be the first...
PostPosted: August 15th, 2008, 17:16
hmm still working on this weird problem
the hard drive went to pc world where someone has tried to swap the logic board
and possible they used the wrong type logic board on it
so the firmware rewritten over the disk (this is possible we are thinking now)
i suppose if the main rom is damaged does this mean the information is lost.
not to sure but we thinking it wroking fine
as you run aff and it says that the drive does not need recovering at all
we tried other programs diskpatch see the drive but zero data
get data back see the drive in windows but comes up with zero data error 55
does not move at all does not find tree files nothing.
O&O DiskRecovery see the drive then we pick the files wanted jpegs
its recovers folders but with zero bytes in them.
could this possible be a head problem not the right headstack
possible we got to match the year up
or possible they changed the design of the head
both drives are made in china so same source
tried hdd regenerator as a test comes up drive pickup in the bios
and the program see the drive
starts to read then comes up bad sector found repaired one and so on
the with in about 10 mins its found over 1,000 bad sectors
any other ideas guys about this problem
when we got the drive it was still sealed only thing someone did
was remove the logic board.
unit has had a full donor exchange headstack changed and platter swap
PostPosted: August 16th, 2008, 6:01
1. Does the serial number shown in MHDD pertain to the one printed on the label?
2. Kill the G-list, like odiferous and others said. You WILL need proper (not freebie) tools to do this.
PostPosted: August 16th, 2008, 12:52
well here the problem killing the g-list
aff says that the drive is in working order and does not need any recovery at all ??????
PostPosted: August 16th, 2008, 21:39
how about the serial?
PostPosted: August 18th, 2008, 19:47
update on this weird problem
run mhdd drive picks up and serial matches perfect so its the right board
when select the scan and repair drive
it starts up and scans
im getting a lot of warning errors
orange
brown
green
red
all comimg up with xxxx
PostPosted: August 20th, 2008, 3:13
any ideas on this guy as we total ?????????? out of ideas
possible the client changed the logic board for not the right model
and possible the service track data has been overwritten our got corrupted.
very weird problem we come across
PostPosted: August 22nd, 2008, 3:20
so update on this problem again
aff emailed us to ask if we got the data of the hard drive
but here to twist there the program comes up drive is 100% working
but we told them the main problem and they are going to look into this weird problem for us.
PostPosted: September 10th, 2008, 4:23
hmmm still working on this drive
any ideas what to try next guys
like i say aff said that the board is working order and does not need recovery
what other problems could i be looking at to do with the head itself
how to match up the right donor
any help guys
cheers
PostPosted: September 18th, 2008, 2:05
so update on this weird problem
aff been in touch and said the drive is working fine firmware etc
g-list is good.
so it looks like the client when they had it to pcworld the muppets
have damaged his files.
Users browsing this forum: No registered users and 58 guests
