 Post subject: WDC WD2500BB-00GUC0-08.02D08 Modules
PostPosted: August 22nd, 2008, 13:19
i have a WD drive, type is WDC WD2500BB-00GUC0-08.02D08. The drive had logical bad sectors in SA and therefore module 02 is damaged. I tried all modules i could find on the net, there is currently none to be found. I rebuilded it using Copy 0 and 1 but there is still one sector missing. Does anyone have modules (especially 02) for this drive? I have attached a zip file with the rebuilded module for comparison, the part from b400-b5f0 is bad due to the bad sectors.
Thanks in advance!
ID02.b400-b5f0-bad.rpm.zip [34.86 KiB]
Downloaded 364 times
 Post subject: Re: WDC WD2500BB-00GUC0-08.02D08 Modules
PostPosted: August 23rd, 2008, 6:46
This might do the trick..... wdc wd2500bb-98gua0-08.02d08-wd-wcal73895294.rar
http://files.hddguru.com/download/PC-30 ... igital/BB/
Good luck
Sean
PostPosted: August 23rd, 2008, 13:53
no, it doesnt, already tried but thanks for the help.
the hdd should have 488 397 168 LBA's. with the module from the fitting hddguru file it has 4 xxx xxx xxx LBA's (dont remember the exact value right now). i have tried many modules, with some the LBA value is correct but i cant access the whole disk so i would guess that the translator tables are not compatible with these modules or they cant read beyond their supposed capacity (e.g. wd1600bb-00guc0, 160 gig). the difficulty seems to be finding the original module because they differ much even if the type is WDxxxxYY-00GUC0. you can take a look in pc3000 database, many 160er modules there, none compatible and they differ.
or could there be another problem i am not aware yet?
anyway thanks in advance for your help,
best regards,
Stephan
PostPosted: August 25th, 2008, 6:08
No one got this module?
thanks for your help
Stephan
PostPosted: August 25th, 2008, 8:14
I've got it. PM me with your e-mail address.
Jon
http://www.datasaversllc.com
Users browsing this forum: Google [Bot] and 80 guests
