Hey all,
Just thought I would check with you guru's (:)) before going a head with a purchase for a similar drive so that I may use its PCB on a failed drive to recover the data.
The background is; after taking the PCB off the faulty drive, you can see exactly where the Motor Controller chip has burnt out and even melted a little bit of the foam between the PCB and the hard drive due to the overheating. The details of the original drive are as follows:
Brand: Western Digital
Model: WD2500JB – 00GVC0
Product of Thailand
Manufacture Date: 23 March 2006.
Logic Board Number (on the white printed sticker): 2061 – 701265 – 200 AL.
Logic Board Number (printed on the PCB itself): 2060 - 701265 - 001 Rev A.
DCM: DSBHCTJAH
Now I've managed to track down a similar drive with the following details:
Firmware: 08.02D08 (Unfortunately I believe I'm unable to tell what this is on the original drive due to it not powering on at all, so can't check in Windows).
Product of Thailand.
Manufacture Date: 19 Jan 2006
DCM: DSCHNT2AH
Do you guys think this is a close enough match? Everything matches except for the DCM values, although ultimately there is only 3 digits difference in the DCM? The manufacture dates are within a couple of months, so I think this may be the closest I'll be able to find. I guess even with a drive that is so close to the original, the U12 firmware chip will still need to be swapped over?
There are a couple of PCB boards on e-bay in the U.S which I might be able to match - again except for the DCM value. I haven't been able to find a WD2500JB – 00GVC0 at all with a matching DCM, although there are 120gig Western Digital drives (after a bit of Googling) which have this DCM. I guess making sure the rest of the details match (Model, PCM/Logic Board number, date) should mostly be enough to ensure success?
Any other hints for a new guy to the trade will be greatly appreciated too
![Smile :)](./images/smilies/icon_smile.gif)
