 Post subject: Seagate Cert problem
PostPosted: December 14th, 2007, 6:02
I have a ST3250823A drive with many bad bloc on one head.
I want to copy this drive under Data Extractor with map creating for disconnect this head.
I have this message : "Invalid CERT Disk code"
I use PC3000 UDMA Seagate Utilities for verify and I have the same message when I want to load CERT.
At this moment I can read sector on drive !
After I switch HDD to ATA mode (age=50) drive not ready and I have this message :
Not interface Age !
INVALID Cert Disk code - ROM resident Revision required : 3.03
Command Inactive - No valid Cert code Detected
T>
How can I restore sector access
Misioux
 Post subject: Re: Seagate Cert problem
PostPosted: August 25th, 2008, 13:15
Hello Misioux;
you had got this problem "I have this message : "Invalid CERT Disk code""
Have you fix this problem, How?
I have that same problem with other Seagate HD.
PostPosted: August 25th, 2008, 14:57
Rewrite Cert code using the SDLD function .
PostPosted: August 26th, 2008, 7:35
Hi rameez and other HDGurus.
sorry but I am novice in recovery.
Whe i obtain Cert Code for my seagate disk?;
and how can i upload the code using Salvationdata "HDD For seagate".?
Thanks.
PostPosted: August 27th, 2008, 14:24
You can obtain the fw for this drive from the salvation data download section .
