Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Samsung F1 (1TB) HDDScan: >700 green blocks. do I return it?
PostPosted: August 27th, 2008, 20:12
Now I am trying HDDScan>Erase.
But it doesn't work. It only reads bad sectors, one after another, very slowly.
PostPosted: August 27th, 2008, 20:57
Have you tried?
http://hddguru.com/content/en/software/ ... tore-Tool/
PostPosted: August 27th, 2008, 21:11
rchadwick wrote:
No, but I am looking at MHDD, which has a lot of functions, one of them is to restore the factory size.
I don't know why the size was reduced to 31MB after that secure erase.
First I want to learn the basics of MHDD, because I don't know what sequence of steps to follow.
Even if I restore the size, I don't know if the sectors will be good again.
PostPosted: August 27th, 2008, 21:22
I wonder if those attempted scans I have done afterwards could have triggered reallocations (because of those Bad sectors-that probably are not Bad after all)...
This MHDD looks very good. ..
PostPosted: August 27th, 2008, 22:58
Trying MHDD:
NHPA (return factory size) doesn't work: "Fail. Try to repower HDD". :?
PostPosted: August 27th, 2008, 23:12
rchadwick wrote:
HDD Capacity Restore Tool
I have tried this, and it worked, apparently.
The capacity is restored, and HDDScan is scanning again!! whoooo :lol:
PostPosted: August 27th, 2008, 23:20
it seems that there are less "greens" than before the accident... too soon to tell......scanning...
the night is young :lol:
PostPosted: August 27th, 2008, 23:27
YESSSSS!!
At the 10% mark, greens are just 9, down from 51 before the accident!! :o :P :lol:
PostPosted: August 27th, 2008, 23:35
scanned 15%:
only 19 green blocks (before 112)
PostPosted: August 27th, 2008, 23:44
at 20%:
39 green blocks (before 179)
so, approximately now I have 1/4 of what I had before.
The transfer rate curve is noticeably smoother.
PostPosted: August 28th, 2008, 0:51
25%: 57 vs 227
30% 60 vs 269
35% 72 vs 324
40% 76 vs 355
45% 80 vs 389
50% 85 vs 414
54% 94 vs 471
58% 99 vs 500
62% 105 vs 527
PostPosted: August 28th, 2008, 1:16
The more you poke with parameters, scan and 'reallocation' (?) the more probably you'll ruin the drive... Good luck. I give up.
PostPosted: August 28th, 2008, 2:07
66% 107 vs 540
70% 107 vs 548
75% 113 vs 554
78% 116 vs 570
80% 116 vs 582
85% 116 vs 592
88% 120 vs 603
91% 122 vs 632
94% 125 vs 665
97% 128 vs 717
100% 128 vs 717
not bad!
PostPosted: August 28th, 2008, 2:12
The HDDScan has been greatly improved after the Secure Erasing.
But I don't know if the drive structure is correct right now. I will have to do more testings... I did a MBR erase with the Samsung utility. Don't know if this is bad or not.
PostPosted: August 28th, 2008, 2:53
Before and after Secure Erase:
PostPosted: August 28th, 2008, 3:43
I have also posted about this whole topic, here:
http://forums.storagereview.net/index.p ... 27117&st=0
you might find some interesting additional info.
p.d: I am going to sleep now.
PostPosted: August 28th, 2008, 4:03
The fact that your still using Windows to scan a drive tells me plenty...
PostPosted: August 28th, 2008, 12:30
I will scan today with MHDD.
I have used HDDScan first in order to compare with my previous results.
PostPosted: August 28th, 2008, 13:36
Now scanning with MHDD in DOS.
10 greens at 10%,
Basically, same results as HDDScan in Windows :roll:
PostPosted: August 28th, 2008, 13:49
35 greens at 20%.
Results are pretty similar.
Users browsing this forum: No registered users and 243 guests
