 Post subject: Maxtor Self Scan with PC3000
PostPosted: August 30th, 2008, 11:26
I am interested in repairing some Maxtors with bad firmware modules using the self-scan feature of the PC3000, to use for hot swap drives.
I have tried it on a couple of Calypso drives, following the instructions in the PC3000 manual, and also several variations of the steps. I cannot get it to complete the process.
Has anyone had regular success with that process, and if so, can offer any suggestions?
Thanks in advance.
http://www.datasaversllc.com
 Post subject: Re: Maxtor Self Scan with PC3000
PostPosted: August 30th, 2008, 12:52
Yes, 100%. You are missing something or wrong procedure or the drives have to be fixed in other parts before SS otherwise you won't succeed.
PostPosted: August 31st, 2008, 15:40
PM me .
PostPosted: September 4th, 2008, 3:29
maybe you need sso file.
PostPosted: September 4th, 2008, 10:08
Could you kindly shed some light on what the SSO file is and its sources?
Thank you.
PostPosted: September 4th, 2008, 13:09
Calypso doesn't need any SSO file. Also you don't need "that" much to start selfscan... :S
PostPosted: September 4th, 2008, 17:53
Thanks, BlackST. But I still am in the dark about the SSO file. What is it and where is it to be found??
PostPosted: September 4th, 2008, 18:35
Main or alternate SA?
http://pcrecoveryllc.com
PostPosted: September 4th, 2008, 21:23
Alternate.
PostPosted: September 7th, 2008, 6:38
U need to find loader for switching hdd to mode C . SSO files are for quantam drives .
Just a curiosity has any one tried selfscaning quantam drives ?
PostPosted: September 7th, 2008, 13:17
Me. Lct and some other OK , AS have all broken modules inside drive. Never succeed - start and then stop immediately. Anyone has solution for AS/Maxtor Mx740?
PostPosted: September 9th, 2008, 14:26
Just the same thing i have many AS / 540k and 740k to be selfscaned i will try i post results .
Users browsing this forum: No registered users and 72 guests
