 Post subject: WD2500JS-40MVB1 - Scans with PINK EXCLAMATION MARKS
PostPosted: September 1st, 2008, 8:23
I got WD2500JS-40MVB1 which acquires on MHDD but scans with PINK EXCLAMATION MARKS. Initially, I thought it was a TRANSLATOR problem. Open it on PC-3000 Utility and performed TRANSLATOR REGENERATION but I got the error message: Format error WD Techno Key Error WD Techno Key Error Device Error Detected 51/04 (ABR). I did a Head Test and SA Structure Test and all seems to be fine. Any suggestion?
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 87871
Head Count.............................. : 1
SPT..................................... : 720
RAM:
Zone allocation table................... : Ok
Read ROM................................ : Ok
ROM version............................. : 10.0RE
ROM generation.......................... : 10.0RE
Link table version...................... : 02.08.
Heads configuration..................... : From map
Heads number............................ : 6
The number of heads in use.............. : 6
Disabled heads.......................... : No
Head map................................ : 0,1,2,3,4,5
Service area:
Configuration loading................... : Ok
Configuration loading................... : HDD has configuration module version : "100R?"
Translation overlay checking............ : Ok
 Post subject: Re: WD2500JS-40MVB1 - Scans with PINK EXCLAMATION MARKS
PostPosted: September 1st, 2008, 9:13
What do u need repair it or DR?
PostPosted: September 1st, 2008, 9:34
I need to repair it so I can recover the data.
PostPosted: September 1st, 2008, 9:45
I guess this means only the data is needed, not the HDD :)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 236 guests
