 Post subject: Atola Insight Question
PostPosted: September 7th, 2008, 14:57
I'm wondering, can the Atola replace the firmware on a drive? I'll give an example: you get a regular drive, can you put the firmware that server drives (I forgot what kind of firmware that is) have on it?
 Post subject: Re: Atola Insight Question
PostPosted: September 8th, 2008, 1:35
PostPosted: September 8th, 2008, 2:55
if you match up the right firmware yes you can
allso it can repair corrupted firmware data .
as for now its beta testing
PostPosted: September 8th, 2008, 3:27
i also heard a lot of this product. but untill now it still is not launched :?:
I just love the world.
PostPosted: September 8th, 2008, 17:53
Perfection takes time ;)
PostPosted: September 8th, 2008, 19:01
Steve, your question is a little strange, are you wanting to make a desktop drive into a server grade drive by changing FW? If so, that will not work. If you want to download and restore/repair FW modules FROM/TO the same disk series: yes it can. I have now read about 30 or so FW's and only one or two cases in which there were troubles (atola still in beta)
