 Post subject: ST3160211 AS FW: 3.AAE
PostPosted: September 10th, 2008, 8:41
Hi to all!
Please look log in terminal (error)
Interface task reset
1024k x 16 SDRAM
TLITE - 1_Disk S-6B 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
ERR Read Boot Adapts
F>
:idea:
Нет ничего невозможного
 Post subject: Re: ST3160211 AS FW: 3.AAE
PostPosted: September 10th, 2008, 8:43
Problem with Boot adaptives. If you have UDMA you can solve this by using a loader.
Best regards,
Dobre
Murphy was an optimist
PostPosted: September 10th, 2008, 9:25
most likely heads or it is platter shift (after drop)
90% original problem not in SA
PostPosted: September 11th, 2008, 13:27
Thanks all replys!!
:mrgreen:
PostPosted: September 11th, 2008, 20:57
PCI3000 loader LDR
/8
C20
SN
N2,,22
PostPosted: September 12th, 2008, 6:55
k25c2yf wrote:
PCI3000 loader LDR
/8
C20
SN
N2,,22
Hi!
please infos!
I can use loader with pc3k pci? How? with which model I must use?
PostPosted: September 16th, 2008, 14:20
k25c2yf wrote:
PCI3000 loader LDR
/8
C20
SN
N2,,22
After loading the C20 command u dont need the # Sn command it has been already loaded to RAM .
Also u need to specify head type MDW or HDW or it will say Adaptives are currupt .
sempre ,
You can use loader with pc3k pci .
Users browsing this forum: ccc and 112 guests
