 Post subject: Anyone recognize this chip?
PostPosted: September 13th, 2008, 14:56
 Post subject: Re: Anyone recognize this chip?
PostPosted: September 13th, 2008, 15:55
The resolution is to small to read, but i would think its a temperature sensor.
Can you give us a close-up of this chip ?
Dobre
Murphy was an optimist
PostPosted: September 13th, 2008, 15:57
Did it come on the drive like that? It appears to just be a chip and a connector. I'm guessing there is no internal connection. My best guess is an eeprom, maybe to hold info (Like a barcode), or to store part of an encryption key, or maybe as some copy-protection-like device? I'm sure someone will know, I'm just guessing...
PostPosted: September 13th, 2008, 15:58
I didn't think of a Temp sensor. That actually makes sense. The numbers should tell...
PostPosted: September 13th, 2008, 16:14
I forgot to look up the chip number on Google. It’s definitely a temp sensor (TMP75). The drive came from a Mac. Why wouldn't Mac use the temp sensor inside the drive?
PostPosted: September 13th, 2008, 16:15
Looks like the drive came out of a MAC.
it's a temperture sensor that shut down computer if drive gets too hot .
PostPosted: September 13th, 2008, 16:16
Anyway, it is really interesting! :shock:
I think too, it has no internal connection.
More interesting part is the jumper pins or connector on the side....
Janos
PostPosted: September 13th, 2008, 16:19
Very cool...looks like 2-wire TI temp sensor...
http://pcrecoveryllc.com
If it is really a temp sensor, it is really interesting solution!
I think anybody can find better place/solution to fixing the sensor, additionally, the drive has own inside.... :shock:
Janos
PostPosted: September 13th, 2008, 16:29
Close up picture
PostPosted: September 14th, 2008, 14:01
I agree, I have seen them in Mac's too.
PostPosted: September 15th, 2008, 13:27
Then, The PCB of the temp sensor is not integrated to the HD, No?
PostPosted: October 18th, 2008, 1:53
Yep, looks like an iMac temperature sensor. All the drives in newish iMacs have these, the plugs on them go into the Mac's logic board and the back side of the little PCB has a sticky substance for sticking onto the HD's. We have to make sure to transfer these when we are replacing iMac drives under Apple warranty.
PostPosted: October 26th, 2008, 17:18
It has nothing to do with the drive. It's attached to the drive by apple to shutdown mac when the drive gets too hot.
PostPosted: May 15th, 2010, 10:04
i believe as you all said, temp. sensor.
but you can read more details of the HD on their website
search for it to make sure
PostPosted: May 15th, 2010, 11:40
Are you seriously going to keep bumping old-ass posts that have already been answered just to repeat the same thing everyone else has said?
PostPosted: May 18th, 2010, 3:57
I guess some people are still a few years behind the rest of us here...
Users browsing this forum: No registered users and 6 guests
cron
