 Post subject: Yet another Seagate ST3500630AS "BSY"
PostPosted: September 16th, 2008, 1:24
I have Seagate ST3500630AS which unable to get RDY, always "BSY" on terminal i got this error, does anyone know what it means please? thank you.
Reset
8192k x 16 DRAM
GALAXY - 1_Disk S-7A 05-25-07_13:14
HM SFI
(P)SATA Reset
Not Interface Age!
INVALID Cert Disk Code - ROM Resident Revision Required: AFZ3A0
Command Inactive - No VALID Cert Code Detected
 Post subject: Re: Yet another Seagate ST3500630AS "BSY"
PostPosted: September 16th, 2008, 8:29
Has this been on Selftest? You probably just need to write the cert code back...I don't have one of these drives so I cannot say more.
PostPosted: September 16th, 2008, 11:57
Hy terranova, are u sure its original PCB from patient HDA?
PostPosted: September 16th, 2008, 12:21
Terminal output seems to indicate that the ROM version does not match that found on the disk. First thing to confirm is if PCB is original.
PostPosted: September 16th, 2008, 12:46
Yeah, right :lol:
The drive has uploaded and executed the application code with wrong version of ROM :lol:
That's must be a very clever drive :mrgreen:
PostPosted: September 16th, 2008, 13:16
Doesn't Seagate make very clever drives?
PostPosted: September 16th, 2008, 16:43
Apparently no :)
I have never seen a Seagate drive which can execute Application code if that code is incompatible with serial flash code :)
The truth is - all manufactures have some sh*t in each model they produced that's probably why DR compainies exist :)
PostPosted: September 16th, 2008, 17:01
Artificial Intelligence?
PostPosted: September 16th, 2008, 20:18
Thank you all, yes it is original PCB, it is from external MAXTOR Onetouch 4, but the drive is seagate. When i got the drive it was sealed and nobody has opened it.
PostPosted: September 16th, 2008, 21:55
just read the cert code with PC3K it probably has some read errors, maybe drive was dropped and it is a small scratch (which goes through SA) on it now
PostPosted: September 16th, 2008, 22:17
Hi Doomer, i have tried to read CERT but failed, i got these errors:
Reset
8192k x 16 DRAM
HM SFI
(P)SATA Reset
Not Interface Age!
T>Age=00 Type=00 MxCyl=00000 MxHd=0 MxSct=000 BSz=016M TCode=00000000 ThermFlts=0000
T>Pgm=00 Trk=FFFFF(168AA:00[1702F]).0(0).1A8(FFF) Zn=E Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=0000085B
T>INVALID Cert Disk Code - ROM Resident Revision Required: AFZ3A0
T>N50,,22
Wrong data format. Write Adaptives rejected
Code - FD Track FFFFF(168AA).0.1A8 Sns FFF Rty F7BF.50.80FF Rtf 1800 LBA 000010AB
PostPosted: September 16th, 2008, 23:11
I meant read the CERT code physically (as tracks) not by Ctrl+R command; to prove it has read errors
And as far as I see adaptives were not initialized which means the drive has read errors not only in CERT code, several other modules could be unreadable
I am very positive about a small scratch now
PostPosted: September 17th, 2008, 2:02
Will loading ldr from same firmware revision work?
Anyone got a firmware for ST3500630AS? The drive has a firmware 3.AFM , eng code. 0AU, ROM S-7A
PostPosted: September 22nd, 2008, 9:55
I also have a Seagate ST350063AS with exact same symptoms, also have firmware code of 3.AFM. In terminal I get the following error:
38(FFFF) Zn=FF Err=A3 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
Pgm=00 Trk=0001602C(0001602C[016FD3]).0(0).238(FFFF) Zn=FF Err=A3 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
I cannot load CERT, and on press CTRL+C I get the following message:
Reset
8192k x 16 DRAM
GALAXY - 1_Disk S-7A 12-08-06_16:41
ERR Read App Code
F>
PostPosted: September 22nd, 2008, 13:47
There is a problem with your Appication code not ur cert code .
PostPosted: May 21st, 2009, 5:58
I've got a match drive with the AFM firmware. I get the same issue as you after a self-scan:
Reset
8192k x 16 DRAM
HM SFI
ERR Read App Code
F>àe - No VALID Cert Code Detected
F>
This drive came from a customer who no longer required the data recovered (hence the self-scan). The issue before I carried out the self scan was that there were bad sectors in the service area. Output as follows:
Reset
8192k x 16 DRAM
HM SFI
(P)SATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=47 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 15ebd.00.022b
DiskAccess ReadSector EC=47 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>À
Perhaps this is a specific issue with the AFM firmware, or slight physical damage / bad sectors in the SA?
Dr. John C. Reid
Cheadle Data Recovery
Manchester ICT Consultancy
0161 408 4857
0161 408 4857
PostPosted: May 21st, 2009, 6:05
You started the selfscan from which age ? 02 by chance ? :mrgreen:
PostPosted: May 21st, 2009, 10:35
just load back app code.... which I guess you kept?
PostPosted: May 21st, 2009, 12:17
Or from identical...
PostPosted: October 13th, 2010, 5:28
Just had a disk in with a similar out put to the initial thread:
(P)SATA Reset
Not Interface Age!
Came from a disk which had allegedly been involved in a computer with an electrical surge. I have a feeling the IT support company had tried to sort it out themselves and had been swapping parts about; this fault was easily rectified on 7200.10 series. I can't say if it was similar issue on a 7200.11/12 whether it would be so easily fixed?
Users browsing this forum: Google [Bot], Majestic-12 [Bot], michael chiklis and 69 guests
