Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: Hi, guys, i have an asking about mhdd
PostPosted: September 22nd, 2008, 22:47
Iam trying to use, for repair bad sectors, ¿which is the option?, ¿I must mark bad sectors?
 Post subject: Re: Hi, guys, i have an asking about mhdd
PostPosted: September 22nd, 2008, 22:58
RTFM.
2 runs: Scan + Remap ON. Scan + Erase Delays ON.
PostPosted: September 23rd, 2008, 10:46
oh friend, you really help me thanks you!!! :)
PostPosted: September 23rd, 2008, 11:16
It is in the FAQ...
Dmitry
PostPosted: September 23rd, 2008, 12:11
BTW if they are really bad there's nothing you can do!
PostPosted: September 23rd, 2008, 14:36
:( it doesn´t work, ¿What can I do, I want that,don´t show me bad sectors, using hddscan, ¿ is there any tool to use, I dont know what´s happend, with hdd regenerator, it is the same problem
Good luck brothers
PostPosted: September 23rd, 2008, 18:56
Good luck brothers
Rxx266,
Can you please post a screenshot? Also the SMART values.
I did not understand what does not work. Do you have bad sectors or weak sectors?
PostPosted: September 23rd, 2008, 21:37
counting_crows wrote:
Good luck brothers
Rxx266,
I want that when i use hddscan, don´t show me, Bad sectors, take off, or mark to use other good sectors, ¿what can I do? using mhdd o hdd regenerator, I dont know what to do, I mean that take a look the pic
PostPosted: September 23rd, 2008, 21:52
Please post SMART screenshot. You can see SMART values in hddscan.
Maybe your hard disk reallocation table is full. That is why it is showing bad sectors. Otherwise, this drive looks good. In modern drives, bad sector remapping is done automatically, you should not see bad sectors in windows (unless your bad sector allocation table is full).
What is MHDD showing in surface scan?
PostPosted: September 24th, 2008, 0:33
MHDD, it is the same, diagostic, that hddscan, but the difference now, that I do, what do you say me before, Scan + Remap ON. Scan + Erase Delays ON. now iam using again, hdd regenerator I think, it is working, on the screen, say: 4 sector repaired. I dont know, I hope have got good luck. Later i give you the information.
now iam interested, that you saying:
Syncelery, I don´t know that problem can you to explain, I have an example about my disk, because the other who have the problem it is running, hdd regenerator sorry. would you be so kind as to explain with my hdd, bye brother
PostPosted: September 24th, 2008, 2:30
This all looks good to me.
I don't know how you can get bad sectors on windows in this scenario. Maybe pros can help.
Please run Western Digital Data Lifegard Diagnostics and choose WRITE ZEROS (all data will be gone, if you still have anything on this drive). Then check your SMART values again.
PostPosted: September 24th, 2008, 22:18
Well, iam very confused, i try with hdd regenerator, i can´t see bad sectors, in combination vmware (virtual machine) configured for use physical drive. there is not. And after running, hddscan,I can see again bad sectors. the ask is ¿why? I dont understand.
I try, with vmware mhdd dont work, just can use, sata cdrom and, 8mb virtual memory as a drive. I dont have time to repeat the process with mhdd but I give you the information for more detail. bye brother, I hope that you can help me =) ;)
PostPosted: September 25th, 2008, 1:28
Because hddreg doesn't do the job. True error remapping can only be accomplished working with the error lists or using internal drive specialized functions, and when possible, not in case of weak heads, for example.
PostPosted: September 25th, 2008, 11:37
vmware, hdd regenerator, windows ??? What are you doing?
hdd regenerator is snakeoil (anyone feel free to counter this).
Go to DOS (DOS... no virtual machine, no windows command promp -- PURE DOS) and run Western Digital Data Lifegard Diagnostics and choose QUICK TEST. If all is good, then choose WRITE ZEROS. Then scan with MHDD (in DOS) and then check your SMART values.
Stop wasting your time with anything in windows at this point. First find out what the real problem is.
Your Reallocation Event Count is 6... your Reallocation Sector Count is 0. This means drive found some weak sectors and marked them pending. But later it was able to successfully recover these sectors (by reading or writing them). Reallocation Event Count records both successful and unsuccessful tries. That is why it is 6.
Your ULTRA DMA CRC Errors are increasing. Change your CABLE.
PostPosted: September 25th, 2008, 11:44
so, I can´t do nothing.?
PostPosted: September 25th, 2008, 12:09
yes, u can, take a new hdd, n keep it to archive
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: September 25th, 2008, 15:52
I just told you what to do.
PostPosted: September 26th, 2008, 17:56
ok thanks, now I take some screenshots with my cell phone, i buy a cabe usb, to transfer to pc, y will post it, be patience. =)
PD: mhdd show me, that "X,X,X,X"=UNC found error at 630415 LBA. SMART I can´t write iam tired. but I think is the same that hddscan bye brother.
PostPosted: September 27th, 2008, 4:56
No need to take picture. Press F10 when SCAN finished. mhdd will save the screen to text log file: scrshot.log
Just paste that here.
PostPosted: September 27th, 2008, 14:22
I know that, but, ¿Where is the log? ¿Where it is saved, c:\?
Users browsing this forum: No registered users and 72 guests
