Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Seagate Barracuda 7200.10 failed to start
PostPosted: September 23rd, 2008, 19:23
Hello.
I think I have a similar problem with a hdd from an external iomega case...
It is a ST3500830AS FIRM 3.AAD
The drive tries to spin up but after 30 sec gives up...
I have recorded an audio file, http://www.box.net/shared/jxhjmjgbxh
put your volume up to hear it...
I have bought a equal drive, should I try to swap the pcb? freeze it? or is it more serious?! :oops:
thanks....
PostPosted: September 23rd, 2008, 20:11
Hi sofa-schlaffi,
I would stick to Pcimage and let him do the work for you, as he has the right tool for that job.
99% that your spindle is stucked and the bearings has broken down, the only (good) way to fix it is to move the platters (3 of them) and heads (6 of them) to a new chassie.
Best Regards
Bosse
http://www.rescue-it.se
PostPosted: September 25th, 2008, 8:26
Hi.
I swaped the PCB and the result was the same, the pcb works fine on the other drive..
What do you think it is?
Should I freeze it?
how many time? 1hour?
PostPosted: September 25th, 2008, 9:05
DO NOT freeze it. That WILL NOT fix it, and probably ruin the drive for good.
Like mr_spokk says, there's a very good chance the spindle is stuck.
Not a job for amateurs, no offence.
We have done loads of these, and it takes specialist equipment and skills.
Best regards
Sean
PostPosted: September 25th, 2008, 9:32
ok... so maybe this guys could do it: http://tecnosupra.pt/Default.htm
they charge about 300 eur + vat for a 500gb HDD...
PostPosted: September 25th, 2008, 10:09
Maybe, but I've never heard of them.
We're in UK, if it's any help?
Or "dmarques" is in Portugal.
Hope this helps
Sean
Users browsing this forum: Google [Bot] and 53 guests
