 Post subject: Samsung SP0802N & replacing PCB
PostPosted: October 7th, 2008, 10:06
Hi All,
I'm hoping someone can give me some advice on the following drive that seems dead. I ran the Samsung diags and the output is below. If I could find a replacement PCB, is that likely to help me, does anyone have the PCB or know where I could obtain one ?
Samsung Diags
Read DMA: Pass
Check M.C. - Error: Media error detected
Check SMART: Pass
Spin Up/Down Pass
Simple Read/Write = pass
simple surface scan : Error: Ecc Error
write verify: Error: Ecc Error
Average Seek time: pass
Average Max seek time : pass
Random Surface Scan: Error: Ecc Error
Model Samsung SP0802N
Serial Number: S00JJ30Y692855
F/W Revirsion: TK100-28
Rev: A
Current size: 76293MB (LBA: 156250000)
Native Size: 76351MB (LBA: 156368016)
Thanks all.
 Post subject: Re: Samsung SP0802N & replacing PCB
PostPosted: October 7th, 2008, 10:18
It's not the pcb, it's the firmware. Everything explained in the line about m.c. (the service area). You can't fix it by yourself, without proper gear. The drive in this state is either recoverable - hopefully - or fixable for re-use but loosing data. How much $ is data worth? Be honest.
P.s. Before you ask, no 'free software' or simple tool can fix it.
PostPosted: October 7th, 2008, 10:24
Thanks for replying. I'm actually helping out a friend, but the quote we had from Ontrack was for 400 UKP. But, with a 2-4 week tunraround (that's not so bad), the data is important but not time sensitive.
PostPosted: October 7th, 2008, 10:28
I meant how much can you afford... Ontrack quote is honest. Where are you located?
PostPosted: October 7th, 2008, 10:31
:-) we can afford the quote. The other quotes were scary. I'm based in Southampton in the UK.
PostPosted: October 7th, 2008, 10:51
Check PM
PostPosted: October 7th, 2008, 11:42
Sorry - silly question, what is PM ?
PostPosted: October 7th, 2008, 11:53
pm means "private message" pcimage sent you a private message about the recovery (i think) :wink:
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: October 7th, 2008, 12:01
Yes ;-)
PostPosted: October 9th, 2008, 16:07
Helpfulguy wrote:
Hi All,
Samsung Diags
Read DMA: Pass
Check SMART: Pass
Spin Up/Down Pass
Rev: A
Thanks all.
Hi ,
Best Bet PCIMAGE Contact him
Great Guy to Be Friends with too
Users browsing this forum: kotel, Majestic-12 [Bot] and 55 guests
