 Post subject: Smoked Hitachi Deskstar HDS728080PLA380
PostPosted: October 8th, 2008, 0:48
I have a smoked Hitachi Deskstar HDS728080PLA380.
Even the ROM chip is smoked.
Will hot swap work on this drive?
Any ideas?
 Post subject: Re: Smoked Hitachi Deskstar HDS728080PLA380
PostPosted: October 8th, 2008, 1:20
High probability that preamp smoked too, but the smoke didn't come out the hda... The risk is frying the new pcb, and anyway you at least need the rom...
PostPosted: October 8th, 2008, 4:57
Hot swap won't work on this.
NVRAM is more-or-less unique for each drive.
Can probably help if in UK, or willing to ship to UK.
Cheers
Sean
PostPosted: October 8th, 2008, 22:22
I can replace the preamp if it is gone.
The big problem is that $%#@ ROM.
Salvation Data's HDD Dr for Hitachi seems like it can do it.
They also claim that PC3000 can't do it.
Anybody know if that is true?
I would really like to do it myself if possible.
PostPosted: October 8th, 2008, 22:39
check pm!
hope this helps.
PostPosted: October 9th, 2008, 14:20
Any ideas?
Hi ,
Check the Preamp ,the Take New PCb Flash Same Version of rom and No a NVram Recovery with Salvation ,And do Tell Us The Secret He Gave You in the PM :mrgreen:
PostPosted: October 9th, 2008, 15:16
Salvation Doctor for Hitachi can read and write NV-RAM. This can be used if corruption occured, but if you have damage to any components to the PCB, it can not help.
NOTE: IF you have a identical drive the salvationdata product can use that NV-RAM to gain access to SA. And there after re-create original NV-RAM config from firmware. I belive there is a NV-RAM backup somewhere on the SA tracks which is used to re-construct the NV-RAM content. As to my knowledge it's the only product that currently provides this function.
Amarbir,
It was no secret, just told him what was logical and worth a try :D
PostPosted: October 9th, 2008, 15:21
Amarbir,
Mate ,
First i Was Pulling you Leg ,Secondly I Honestly Belive There is No NVRAM in the Firmware .What Salvation Does is
We give it a identical family nvram ,Then it searches for some signature in the firmware when it finds that it records that to the nvram we used as donor .Our firmware is then recovered as now we know the location ,After that we save this nvram and then make it search the data area ,It again searches for the same and we have a fully functional drive .
PostPosted: October 9th, 2008, 15:28
I am a bit short, so please pull both legs, maybe I'll gain a few inches in height :lol:
Is that a statement you got from SD support?
PostPosted: October 9th, 2008, 15:38
No ,
Thats My Own Though About NVRAM Recovery .
PostPosted: October 9th, 2008, 15:50
Well ok Amarbir,
maybe you are right, I don't know. I don't have any time to do any research on it at the moment. But either way, DRNJ now has a few more things to try with the Deathstar.
DRNJ,
Let us know of your outcome!
PostPosted: October 10th, 2008, 9:53
I am not a Hitachi Doctor owner, but I rather think they use brute force to find out the SA location on the surface.
...since it is just impossible to know where it is once the NVRAM is gone...
PostPosted: October 30th, 2008, 23:50
The customer got upset because I was taking too long and took the drive back.
Maybe one of you guys will get it next.
Thanks for all the help. I will have a few more things to try next time.
Users browsing this forum: No registered users and 225 guests
