 Post subject: 500 GB SEAGATE HARD DISK NOT SPINNING
PostPosted: October 8th, 2008, 10:46
500 GB SEAGATE HARD DISK NOT SPINNING I CAHNGE LOGIC BOARD OF THAT BUT STILL NOT SPINNING
 Post subject: Re: 500 GB SEAGATE HARD DISK NOT SPINNING
PostPosted: October 8th, 2008, 11:13
Spindle likely frozen.
PostPosted: October 8th, 2008, 11:19
Almost certainly frozen spindle, like rchadwick says.
Common on these.
Not a DIY fix by ANY means!!
PostPosted: October 8th, 2008, 11:25
Spindle seized . The cause : shock or drive dropped or severe overheat leading to "grip" , regardless what the user said :D (only in a few case it was simple mechanical failure). Prepare to spend $$$$$$$ (or €€€€€€€€ or change the symbol to your currency).
PostPosted: October 8th, 2008, 12:02
Agree , u could check too by terminal log, if u got Buzz...text surely its FDB problems like hddguru´s told u
PostPosted: October 8th, 2008, 13:30
Agreed, FDB PROBLEM
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 9th, 2008, 15:06
Well ,
Very Very Common Issue In those Drive ,Its Impossible To Move the Platter .a Hardware Tool To Take The Platters Out And Then Free The Sindle Motor Or Complete Swap toanother drive will help .If You Are Not into DR field i will Suggest you Send It you Someone Who Does ,If you Are Invest In These tools and LEarn And Make Money .
PostPosted: October 10th, 2008, 6:26
A client of mine recently had one of these dealt with by Attingo in Austria after a couple of companies over here could not do it.
PostPosted: October 10th, 2008, 6:51
Sometimes even the big companies refuse to do some jobs. DOn't know why...
Can you post how much was the expense, if not confidential ?
Users browsing this forum: Bing [Bot] and 232 guests
