 Post subject: HTS541612J9SA00
PostPosted: October 9th, 2008, 14:29
Hi to all!
this hd when binding has rpm, but not moves heads look log!
It they problem in nvram?
on- DRD-DSC ERR-ABRT
Selected family......................... : HTS548
Model by ID............................. : <ID IS NOT READ>
NV-RAM reading........................................................ : Error
Initialization error
Error : Error switching to techno mode
UNIVERSAL UTILITY
HDD does not support set max LBA
HDD does not support S.M.A.R.T.
Write cache............................. : not supported
Soft reset ...
Ok
Determine rotational frequency
RPM..................................... : Fail to determinate
Bus test started (ports x2, x3, x4, x5)
Writing "00" to ports
Status.................................. : Ok
"Running set to one bit" test
Writing "FF" to ports
"Running set to zero bit" test
Errors not found
Sector buffer test
Ok
Write sector buffer error (ABR) 51 / 04
Soft reset ...
Ok
IRQ Test
Ok
Нет ничего невозможного
 Post subject: Re: HTS541612J9SA00
PostPosted: October 9th, 2008, 14:33
sempre wrote:
Hi to all!
UNIVERSAL UTILITY
Soft reset ...
Ok
Errors not found
Sector buffer test
Ok
Soft reset ...
Ok
IRQ Test
Ok
Sempre ,
That DR tools you Have I Know you Are a Old Seasoned DR Pro But then also was interested
PostPosted: October 9th, 2008, 14:41
Sempre ,
That DR tools you Have I Know you Are a Old Seasoned DR Pro But then also was interested[/quote]
not I understood!
PostPosted: October 9th, 2008, 14:43
sempre wrote:
Sempre ,
not I understood!
:?:[/quote]
Mate ,
I Was Asking Do You Have Salvation And Ace tools
PostPosted: October 10th, 2008, 13:32
Some help??
Wait....
:roll:
PostPosted: October 10th, 2008, 14:18
no comment
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 10th, 2008, 15:16
Hi ,
It Could Be the PCb Please Change And Try ,This is a Stepper Motor And even One BaD channel Will Have a Issue
PostPosted: October 27th, 2008, 18:26
I am having issues with this same drive. Every 3-4 seconds I could hear the heads trying to read. Where do I start on how to diagnose what the issue could be?
Thanks,
-JR
PostPosted: October 27th, 2008, 19:41
If hdd reach´s readiness u could tried to did a surface scan, and check how many and wich kind of sectors show like bad check at ATA registers , but if u heard the hdd trying to read could be too surface damaged or MHA problems,
PostPosted: October 28th, 2008, 20:28
Actually, I try to connect via USB and would not load. Cannot see in device manager or dir tree. I do a direct connection (laptop) and get BSOD device error.
PostPosted: October 30th, 2008, 10:26
connect using 2.5 to 3.5 converter, report using MHDD.
__________
THANK YOU
SHAHI
PostPosted: October 30th, 2008, 13:48
Yes conected using 2,5 to3,5 converter,report mhdd.
Not ready => LBA 0
DRSC DRDY ABRT ERR
Users browsing this forum: Bing [Bot] and 141 guests
