Hello gurus,
Now I am trying to selfscan one 7200.7 (PUMA) drive.
The selfscan started good, but after some hours, I can see the drive gets in endless loop in test 40.
Quick Error Rate cyl 164D8
Rbit Hard Firm Soft OTF Raw Rhdr Wbit Whrd Wrty Whdr
Limit 10.2 10.2 9.5 8.0 0.0 3.9 7.4 9.2 9.2 6.5 7.4
Hd 0 8.6 8.6 8.6 8.6 8.6 6.1 8.6 8.3 8.3 8.3 8.3
Hd 1 8.6 8.6 8.6 8.6 8.6 6.8 8.6 8.3 8.3 8.3 8.3
OTC characterization
Track 0130D
______ISO_____ ______PE______ ______OTC_____
Head Sctr Min Wid Sctr Min Wid Sctr Min Wid
0 2260 000C 0031 2260 0019 001D 2260 0022 0025
1 2260 0018 0023 2260 0058 0002 2260 0048 000D
Track 164D8
0 203a 0029 0023 203a 0038 000F 203a 002B 001D
1 203a 0001 0045 203a 0004 002F 203a 0004 0035
Power Cycling
ASCII logging off
OkEnd Test 58
Begin Test 40
ASCII logging on
Head Mask FFFF - Switch to full int.
Spin Ready
Spin Ready
Spin Ready
Spin Ready
Spin Ready
Spin Ready
At this point, I have switched off the power and on again.
The drive shows this:
4096k x 16 buffer detected
PUMA - 1_Disk M-22d 11-11-04 10:47
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.43 01-26-05 16:23
(P)(H)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .083
Cert Table loaded
No script first instruction.
No valid SeaDex script on disc.
Begin Test 40
ASCII logging on
Spin Ready
Spin Ready
I have changed the AGE from 40 to 41.
The test continues, but i am not sure on the right way.
Now the drive is on this state after more than 24 hour:
Begin Test 49
ASCII logging on
ASCII logging off Not Power Cycling
ASCII logging on
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, NPML=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=0, ECC 2=0, ECC 1=1, ECC 0=1
Data=40, Write=80, ID=FF
ASCII logging off
All Hds 0-1, All Cyls 00018-164F8, Rnd data
ASCII logging on
Score= : #
Measured spin speed: 407 ticks per rev (48 ticks per millisecond)
EndLBA,Pred,Act,%Deg,Score
(only repeate noise, no more messages)
Somebody can help me how to step back to the normal way of ss?
Thanks!
Janos
